While that thread would help with how many miles are on the NMS passat in general, It would not help him narrow it down to the '15 Passat and and potential problems with the EA288 engine.You may want to check out this existing thread How many miles on your passat ?
Thanks, that was going to be my reply. I'm specifically concerned about the HPFP and AdBlue heater and things that I "hope" changed with the EA288. Long term, my plans right now would be to add the 2 micron AFTER the warranty expires, but I would love it if a lack of failures caused me to not find that necessary.While that thread would help with how many miles are on the NMS passat in general, It would not help him narrow it down to the '15 Passat and and potential problems with the EA288 engine.
If you want to get technical... There is nothing B7 about any of our NMS Passats.There is nothing B7 about it.![]()
I agree and that's why I responded. Other than bore spacing I believe everything to do with the ea288 is different from the previous tdi so we should be looking for trends within the 2015. Although there is very few of them out there it should still be tracked. My first uoa @20k miles showed markedly lower Al than the previous TDI's so something has changed.While that thread would help with how many miles are on the NMS passat in general, It would not help him narrow it down to the '15 Passat and and potential problems with the EA288 engine.
Is that Aluminum?My first uoa @20k miles showed markedly lower Al than the previous TDI's so something has changed.
Yes aluminum.Is that Aluminum?
I use the VCDS from Ross Tech and re-set it. Works well.Purchased on 5/12/15, 34,000 trouble free miles so far. Only complaint is a minor one. I do all of my own maintenance, and I have not been successful in getting the oil change reminder to reset. I have tried multiple times. Since it only chimes once on startup, not a big deal.
I plan on doing all my own as well. My long term plan is to keep it stock until the warranty is over, unless there is a "tune" that is required as a result of dieselgate. If that happens, then I'm heading to Malone the day afterwards.59,000+ on my 2015 passat, bought 1 year ago, 0.0 problems. Bought new tires recently, now the tire pressure sensor light is on. Malone Stage 2 as well. Do all my own maintenance. Great car.
It means the oil change countdown has expired and needs to be reset. You can do that through the multifunction display menu.50,450 on my 2015. Have "Inspection Now!" showing on my MFD, but no codes. Trying to figure out what this means.
This is how to reset the 2015 for the service interval:50,450 on my 2015. Have "Inspection Now!" showing on my MFD, but no codes. Trying to figure out what this means.
