Who has a Vag-com, scan tool, and where?
Little Stevie
Nashua, NH USA
1984 Westy with 1998 AFN, VNT17/22 hybrid, Stage 4
VCDS, cable and laptop in Nashua, NH
Happy to help, in the greater Nashua, NH area. I'm located near Haywards Ice Cream.
OldbridgeMike
Old Bridge NJ
2003 Jetta TDI
Vag-Com & Bentley Manual
I have the Ross Tech KII-usb Vag-com including the software, and the Bentley CD book. I also have a Laptop to use the system.
I Live in Old Bridge NJ, anyone that needs to use it feel free to ask.
VCDS License with KII-USB Interface
Volkswagen
Golf, Jetta: 1999 - 2005
Jetta Wagon: 2001 - 2006
GTI: 1999 - 2006
and CITY models through 2009
Repair Manual
on DVD-ROM
vwmeche94
Opelousas, LA
Golf MK4 (IV) TDI
Does anyone have any experience with any of the following?
http://www.harborfreight.com/can-obd-ii-professional-scan-tool-60694.html
http://shop.advanceautoparts.com/we..._10188482-p?searchTerm=can+scanner#fragment-1
Or the 3160 which is the next model
http://www.amazon.com/MaxScan-VAG40...e=UTF8&qid=1370266697&sr=8-1&keywords=maxscan
I am wanting to get my own tool for diagnosing and clearing up issues with my 99.5' Golf TDI (ALH) and would like to get some opinions on accuracy/benefit of any of these or others that won't break the bank.
Crankous
Wildomar Ca
2003 Jetta wagon GL 5speed w/Panzer FMJ, 2005 B5.5 passat auto, 2000 Golf 4 door 5 speed
There is a much better place to put that question. It is in the "OBD Scanners" section. located here: http://forums.tdiclub.com/forumdisplay.php?f=21 This is really only for VCDS tool locations and who has them and are willing to lend a hand to other members. :)
St. John's, NL
2005 GOLF TDI GLS
Vag-com
I live in St. John's, Newfoundland. Is there anyone around here that has a VAG-COM? Otherwise, how much should I expect to pay if I were to buy one?
ihatespeed
holbrook, ma
11 tdi wagon 6mt 15 golf 6mt (Wife's) 2000 Ford 350 7.3l 6mt 4x4 (technically a TDI)
I have one in Rockland Me, happy to help if I'm in town!
djgdjg
rbc al.
repair shop
Ross-Tech VCDS and VAG TACHO
I have a Ross-Tech VCDS and a VAG TACHO i am in Gadsden/Rainbow City Al. area
TDI-DIY
Fall City, Washington
Mk4 - MK7 (2x)
HEX-CAN and VCDS Laptop in Fall City Wa, 20 miles East of Seattle. Also have TB tools for AHU and ALH. Motive bleeder and topside oil extractor, etc. Always glad to help...
DieselDork
Bothell, WA
2004 BEW
Noob to the forum. Not to my diesel.
Greetings,
I finally joined. I've been finding bits and pieces of info from this forum since I bought my 2004 Tdi BEW. Thank you all for being here. After ten years of owning my beloved "Sheba" and putting every single mile less 50 on her 203k miles, I want to finally make her the Dream Diesel I've always wanted. So this far I have added a short shift from an Audi TT and just received a from sway bar from Eibach and entry level performance front struts from Koni. I figured suspension was a good place to start. A front tie bar and a bushing refresh will be next. Down the road I want to max out the engine, but with baby steps. I seek guidance on what steps to take on the road to upgrading the engine. I have heard injectors and a chip is the best first move for a diesel instead of gasser logic (intake and exhaust). Thoughts and comments welcome.
Joequin
Leominster,ma
2002 Jetta GLS Sedan 2.0
Live in Massachusetts DESPERATE need of a VAG-COM
Please contact me if you live in the MA area and can help me out with a VAG-COM. I just replaced the throttle body & accelerator pedal position & need to have a relearn in order for it to work! PLEASE HELP if possible:confused:
Vince Waldon
Edmonton AB Canada
I gather you are talking about a gas engine? On the Diesel engine the ECU doesn't need to be taught, at least in my experience, although there is a procedure you can use to make sure the ECU understands the full range...don't recall the exact steps but it involves leaving the key in the ON position and cycling the pedal thru the range. Google might track it down.
Joequin
Leominster,ma
Yes its a gas engine 2003 Jetta GL 2.0 standard. I have done the DIY manual steps (didn't work) I was told without the reprogramming with a VAG-COM the pedal will not communicate with the throttle body to make it accelerate. I am getting codes P2138 & P2128 and have done everything except to use the VAG-COM.
tromano32
Cleveland, Ohio
2001 Golf TDI GLS 5spd 249k miles
Anyone in the Cleveland Ohio are who can loan me , rent to me, or sell me a genuine vcds cable for my 01 golf ?
