ninedee_golf_tdi
Do you have a "cruise" lamp in your dashboard like the later a4's do ? I have tried 3 different stalks and none illuminate that lamp if it exists. The cruise does work and vcds does show all switches work.
With a bit of work, you can upgrade to an Immo3 cluster and you will have the cruise control light. Then, once you have a newer cluster installed, there's a byte you can change in some cluster EEPROMs that will fix it so the light turns on only when the cruise is controlling the speed. I have it working that way in my '99.5 with an upgraded cluster.99.5's dont have this.
It's annoying anyway, all it shows is that the switch is on, not that it's driving the car.
-J
Good to know! I assumed the new stalk wouldn't work with the older ECU.You can change the column switches out easily - I installed the updated style when the original stalk in my 99.5 wore out.
Learn something new every day. I have a 99.5 and an 01 and they both have the old style cruise stalk. I didn't even realize there was a newer style.You can change the column switches out easily - I installed the updated style when the original stalk in my 99.5 wore out.
