Hi, I have a 2002 mk4 golf tdi. I deleted the EGR and tuned it. A year later I blew the turbo pushing to much boost. This caused a runaway engine. The engine ran for about 2 min at max rpm then ran out of the external fuel source. I now installed a slightly bigger turbo and took the EGR cooler off, by passed the coolant line, cleaned the IC, rebuilt the injectors and cleaned the nozzles. I started it up and it’s a rough start, have to use starter fuel every time. Blows a lot of white smoke and the throttle is boggy. I checked compression and it read between 350 and 400 psi for all 4. I’m also leaking a little bit of oil right under where I installed the new turbo. Any suggestions would be great. Thanks
