poor_passat
I personally have never heard of head cracking in PD engines. Well you two are stating the two ends of the scale. I must be in the middle somewhere.
By the way I have BJ injectors, they said to be capable of same flow as the AL ones. Here in europe everyone beats the ARL engines (and AL injectors), even the block is harder material then all the other 1.9 PDs. Less people seem to do that with the 2.0 engines, but they should be same material as the ARL ones.
I think what your 250HP engines can produce in power, is more linear and smooth then what I'm used to. Nothing 'till 2300rpm, then like someone slap you in the back of your head. It makes sense to build the engine harder if you want torque in lower rpm range, or you want higher redlines. Around here engines said to produce 250HP (might probably be 220ish) don't have anything other than bigger turbo. They don't usually fall apart, to be honest. They occasionally do, and that is not what I'm going for, but they take suprisingly much.
I know someone, who had worked at VW when developing theese engines, and he says the ARL engine was made to produce 600HP in labs, wihout falling apart. The drivetrains were not capable of the power though.
