I really don't know how far the PD I-beams can be pushed. Don't really want to find out, as I think just because the manufacturing process is made by cracking the cap off of the rod, that makes be suspicious of the material. Yes, I know the cracking is done under extreme cold, which makes the material even more brittle. I wonder what happens with CrNiMO rods if you were to try cracking them. Would it work or would the material bend? That is the whole point of the 4340 H-beams; toughness.
When the European builders say 'only 250hp', and say that's not a race engine, I wonder what world they are living in. To get a 1 horsepower per pound of engine is A RACE ENGINE. When you can spin the wheels by just stomping the pedal in 4th gear (and sometimes 5th), that's a race engine. And I do not mean just because the same block that initially made 90 hp is now 110, 130, 150, 170hp, so, 2x hp does not mean you can double 170! At least not reliably. 340hp is for the weekend track star.
I'd also mention the Tiguan engine, 2.0 that has dual turbo, 240hp. Just because VW built it with that hp, does not mean it was intended to last. I've got a video of some of those engine's cylinder heads completely worn out at 80,000 km. That is not my idea of a competently built engine. It's the Anti-bulletproof engine. The high pressure fuel pump lobe has an inspection interval of 20,000 miles. So, every time you change your air filter, you have to inspect a crucial engine component?? You've got to be kidding! I think I could build another impressive improvement, just on that POS part.
I have to admit, going back to 1996, the TDI crank has tremendous appeal for me. It's journals look to me as big as the 289 Ford small block, which we felt we were making a monster engine when it had 300 hp from what is approximately a 3.9 liter engine. Sure, I'm talking gasoline and technology from the 60's, but that engine is almost double the displacement compared to the 2.0 TDI. (Oh, by the way, that 289 ended up being a stroker.. 302, reverse logic in today's world...) and then you expect to do more power from 1/2 the volume and not call it a race engine, there is a conclusion that is easy to reach. Life expectancy goes in the toilet.
It was one of the standards, even way back then, to build with the H-beam. But most people do not know or understand, bean-counters (accountants) are building your engine. Why I-beams? They are cheaper to stamp out in a forge. BANG! BANG! BANG! your done... Why Cracked Rods? Cracked rods are 30% cheaper to build. Why H-beams? Strength and torsional stability. I'd go head to head with any I-beam, because we built our rod to be 'bulletproof'. Bulletproof and cheap are not synonyms.
I know there is more capability from the 2.0 blocks, but only with a lot of determined care in building and a lot of thought to make that 'bullet proof'.
Some are gamblers and like to talk about the successful runs of luck. Problem is, whenever I have blown up an engine, it's wasn't 'bad luck'. It was R & D, testing the raw edge and learning the hard lessons.
So, if your attempt is to build structurally sound, the best thing is to build overkill or detune to safe levels. 2 of the 1.6 IDIs I owned managed to make 1.2 million miles (nearly 2,000,000km) between them. Neither one had 60 hp, and the only thing they could pass was a gas station. But you couldn't kill them. When I finally sold them, both engines, were still running and capable of nearly 60mpg. I just got sick of looking at them. Heh... I'd rather have my 165hp Passat 2.0 PD's comfort and power... not too much extra, but very sustainable for a lot of miles.
