Felly123
- Joined
- Mar 13, 2023
- Location
- Willow Springs Missouri
- TDI
- 97 Passat, 2018 Equinox TDI, 2005 F350 6.0.
Changing injectors on my 97 passat. For the best fuel mileage (long Commute) which is best Bosch .230 or .260. Thanks
Thanks Brother.Smaller Injectors will give you better mileage.
Thanks Burpod, I've got the Bosch .230's on the way. Don't know what I'm running now, will have to see when I get them out. I'm tired of smoking everyone out at every stop light.you really can get the same or better mpg with larger nozzles. but thats only if the tune has really been done right and good most aren't far as i can see.... with a basic name-brand tune, the bigger nozzles don't run so well except for making more power and usually a bunch of smoke. doesn't have to be that way however.... i have 11mm + .260s and no smoke anywhere, no lag either.. mpg has never been better
