SoTxBill
- Joined
- Dec 14, 2000
- TDI
- 13 passatdsg 10 jetdsg, 09 jetdsg, 2006 jetdsg, 2001Jet, 96passat, 86jet, 81 jet, 78pickup all vw diesel.
maybe Im all wet,, but I would get a coolant heater.
with the newer synthetic oils,, cranking is not a problem..
the coolant heater will fool the ecu into thinking the engine is warm and thats ok because it is warm...
No different that if I drove my car in winter,, then stopped in a store for an hour and came back out..
The snow is still there and its still cold out side but the water jacket still has some heat in it.
the engine will start quicker, and the heater will be warmer quicker and you will save fuel "quicker".
oil pan heaters were great when we ran streight 40w in our diesels in years back, but excellent oils like amsoil (for sky pup and other group III/IV oils have very low poor points (-50).. If your howver in the artic,, then you need both and a heated garage..
