arjax
I have a 01 C5 BHW swapped allroad that I am contemplating replacing with 3L TDI V6. I wanted to see which year of the 3L would be the best candidate for the swap. Thoughts?
TIA
TIA
Compared to what?it still feels underpowered.
No doubt...sometimes I forget what's being asked of this little engine. The "underpowered" comment was ambiguous and you're probably correct that it is more a problem of expectation. Last night the car died while just cruising home at about 45 mph. It's looking like a timing issue as I have code for the cam position sensor (CamPS) being out of range p3008. When the CamPS is plugged in the car won't start. I had pulled the glow plugs to see if fuel was being injected and it wasn't. When I unplug the CamPS, then fuel started to be blown out the glow plugs holes. It now starts but it runs rough and dies every time about 5-6 after firing up (I tried to raise revs and then kills). So I am hoping it is just a bad sensor. If it is, it might explain why the fuel economy over the last little bit has been down and even some of the feeling of being underpowered.Don't forget this is a little engine in a big heavy car turning four big tires and five driveshafts.
19464 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range
Freeze Frame:
RPM: 1764 /min
Torque: 86.0 Nm
Speed: 46.0 km/h
Load: 25.1 %
Voltage: 13.83 V
Bin. Bits: 00001000
Idle Stabilization: 0.0°KW
(no units): 35.0
