adamant628
NB_TDi said:Eyes on the road!!
ok, let's say "I can't see it when I'm sitting at an intersection with the wheel turned"
Yes, the automotive velcro holds even in the S. FL heat. I tried two other types that didn't hold before finding the automotive, it held for two years. Recently had to move the SG over and couldn't find the automotive this time. Got "industrial" instead and it doesn't hold in the heat.I found that I had to go get some automotie specific double sided sticky velcro and cover the entire top of the scangauge to get it to stick and last any ammount of time - particularly when it got hot out.
I don't have a picture of it handy, but I do have a video.
http://www.youtube.com/watch?v=Qwk3MNroYYI
As you can see, I like to monitor a few things......
I thought it would be temporary (covering the temp and fuel gauge), but the temp gauge is useless and I really don't need to see the fuel gauge either, when the low fuel light comes on I've got 100 miles to fill up which is enough warning for me.
I'll have to give that automotive velcro a go. If I place the SGII under the visor like you said might be kinda hard to hide the cable?I found that I had to go get some automotie specific double sided sticky velcro and cover the entire top of the scangauge to get it to stick and last any ammount of time - particularly when it got hot out.
You might try locating it on the underside of the gauge "visor" - basically - where it was located above the steering column in your middle picture - move it away from you until you hit the clear plastic of the gauges and then raise it up until it hits the top of the "visor" for the gauges.
That way it won't block your fuel/temp gauges, stays relatively out of sight of criminals and is a quick glance to read just like your other gauges.
Yes - the cable is exposed. I ran mine along the right side edge corner of the visor and followed it around to the steering column where it disappears under the dash to then plug into the OBDII port. If you look for it you can find it, but it's a black cable in the corner next to a black visor with a black background so you essentially never see it unless you look for it.I'll have to give that automotive velcro a go. If I place the SGII under the visor like you said might be kinda hard to hide the cable?
I took the case apart and soldered momentary-on push button switches into the solder pads on the circuit board. The switches and the screen were mounted to the backside of an OEM cupholder blank. I used a dremel to cut out a rough square shape for the screen, and used mini files to file it into a perfect rectangle. I marked the locations for the buttons and drilled holes that were slightly undersize, and then used a tapered reamer from the backside to get a perfect fit for the buttons.Great install, Frequent Flyer! Can you provide any more info about how you built that? Would be a great option for people with double-DIN radios, because the ScanGauge is normally too tall to fit in the cupholder space.
I often wanted to do that since I get that a lot and I hate it. I kept thinking about it but I am not an electrical person. If it is an easy job, can you tell me what you did? Either email me or make a separate post so others can benefit. Thanks.Switch on the left is a momentary and turns the brake lights... a "tailgater repulsion system" that works great.
Tried to PM you, so as not to threadjack, but you seem to have that turned off?? Send me a PM and I'll reply!I often wanted to do that since I get that a lot and I hate it. I kept thinking about it but I am not an electrical person. If it is an easy job, can you tell me what you did? Either email me or make a separate post so others can benefit. Thanks.
