Which Location?$2.45 for propel high performance
According to GasBuddy:
MORE VARYING PRICES WITH DIESEL
Diesel fuel is typically more expensive than regular gasoline for a few reasons:
1) It is taxed higher at the federal level than gasoline.
2) Refining diesel is more expensive than gasoline.
3) Fewer gas stations sell diesel fuel, making the distance from pump to pump even more expensive.
The part about diesel costing more to refine goes against everything I've ever heard? Can that be accurate?
https://www.gasbuddy.com/go/how-to-save-money-on-diesel-fuel/
I don't think so.According to GasBuddy:
Yep, I remember my Dad tell me way back when diesel tractors hit the market, they were practically giving diesel away. It was the waste from gasoline distillation. Either way it takes less processing to get from crude to diesel than from crude to gasoline.I don't think so.
When kerosene, a close relative of diesel #2, came out in the 1800's refining a barrel of crude came with a waste product: gasoline. ULSD was only supposed to cost $.03-$.05/gallon more than LSD at the time when diesel was cheaper.
It's the same process. It's called fractional distillation. Diesel fuel actually requires more processing now to remove almost all of the sulfur. But the main reason diesel is so much more expensive at the moment is all about supply and demand. Economics 101.Yep, I remember my Dad tell me way back when diesel tractors hit the market, they were practically giving diesel away. It was the waste from gasoline distillation. Either way it takes less processing to get from crude to diesel than from crude to gasoline.
The GasBuddy statement is wrong.
Good point. I guess ULSD is not your fathers diesel. lol More processing to remove the sulfur. Makes you wonder if there is a market for all the sulfur they capture.It's the same process. It's called fractional distillation. Diesel fuel actually requires more processing now to remove almost all of the sulfur. But the main reason diesel is so much more expensive at the moment is all about supply and demand. Economics 101.
Simple answer: Over the road taxes. With the possible exception of states that are CARB compliant, I don't think there's a conspiracy at work.I mean come on, heating oil is 1.79. Diesel is 2.99.
The first statement is the only correct one. Even federal taxes on diesel are higher than gasoline.According to GasBuddy:
According to the latest data from EIA (https://www.eia.gov/dnav/pet/pet_cons_wpsup_k_w.htm), U.S. weekly consumption of gasoline has dropped nearly in half (~5,000,000 barrels/day compared to ~9,300,000 barrels/day typically).
Distillate consumption has dropped some (from ~4,200,000 barrels/day to ~ 3,800,000 barrels/day). Jet fuel consumption has also dropped by nearly 50%.
In any normal situation cheap gas would increase consumption. I don't think that really applies to our current situation though. Refineries are having to reduce output and even shut down due to the lack of storage and poor profitability. It looks as though OPEC+ has agreed to stop flooding the market at least.Pricing is the quickest and easiest way to respond to changes in supply and demand. Structural changes in refineries are much more expensive and take much longer to implement.
I doubt we'll see any refinery changes since the current trouble is going to be seen as temporary. What to do with a 50% drop in consumption of gasoline and kerosene resulting in no extra storage available (once we're full up) will be interesting to watch.
Cheers,
PH
Mom told me that she paid under a buck for rug in Des Moines, Iowa on Saturday. I haven't seen it that low since the early 80s. I remember when the stations started pricing by the half gallon becasue thier pumps and signs did not have room for more than two points before the .9.Current futures price for a barrel of oil is less than $13. That is beyond silly. Beyond insane even. And extremely dangerous for many oil producing countries. Also companies like Diamond Offshore dirlling, Noble Corp, Nabors industry, and several others are heading for certain bankruptcy.
Expect gas prices to approach $1 (or less) a gallon in most areas if it stays this way for any length of time
Some places are already lower than $1.
Supply and demand 101 here.
