03tdiwagon
Hey guys back again with more reoccurring issues
- 3 months back I had vibrations in my steering wheel while braking ONLY BETWEEN 60-45 KM (ballpark)
- I removed the front and rear brakes and noticed they were decent quality zimmerman rotors with trw pads surprisingly.*
- I changed all 4 corners again with brand new zimmerman rotors and trw pads. As well as 2 new front oem rebuilt calipers .
Starting last week I noticed the vibration (not as severe as before and also only from 50-45 KM not 60-45km like before ) was present again. Sure enough every time I brake between 50-45 my steering wheel vibrates a little
I need help figuring this out . I'm thinking it's a hub because the new brakes may of masked the issue of it being bent or a failing bearing, but now that they have 7k on them the issue may be arriving again . If it was a suspension issue I believe it would've always been present and not masked by new brakes . But I'm open to any suggestions to things i can check*
THANK you for any help in advance
