12MPGHWY
How about an FJ80 land cruiser, estimated realistic max gross weight is 6000 pounds with a 5000 towing capacity.
The stock engines bhp (manufacturer specs):
1991-1993 is 155 HP and 220 lb ft torque with torque peak around 2500 rpm engine is pushrod OHV 4.0L I6 red line is 4500 rpm
1993-1997 is 212 hp and 275 lb feet torque peek about 3200 rpm, engine is OHC 4.5L I6
I would bet money that my A3 with AHU VNT 2056 tune and R520 injectors would best either in torque, and match or come very close to matching the latter in HP on an engine dyno with more of it down low, and probably a broader spread of power and torque.
Incidentally my land cruiser is a 1991, so I have the less power full engine. The AHU in my A3 would push the pig around better than factory engine without a doubt.
But... how long would it live in such a heavy and very non aero dynamic vehicle running so far beyond the capacity that VW designed it for?
Is this a good idea?
Thoughts on using a built up VE pump 4cyl TDI to push a 6000 pound car with the aerodynamics of a barn door.
