- Joined
- Jul 2, 2000
- Location
- Springfield, VA
- TDI
- ‘18 Tesla Model 3D+, ‘14 Cadillac ELR, ‘13 Fiat 500e
And the Ford 5R110W is a 6-speed that switches patterns from 1-2-3-5-6 (normally) to 1-2-3-4-6 below 5 degrees F. (4th is 1.09:1, 5th is 1.00:1.)
However, the DSG has the issue that shifting between odd and even gears is fast, because it preselects the gear in the other box based on what it thinks you'll want, then switches clutches when you (or it) wants the shift. Skip-shifting between odd gears alone, or between even gears alone, is not fast, though, because then it's forced to act like a single-clutch gearbox - disengage clutch, shift, re-engage clutch.
So, a 1-4 shift on a DSG can be as fast as a 1-2 (well, plus the time for the clutch slip to resolve itself), whereas a 1-3 cannot be, for instance.
Also, fast shifts on a DSG allow for some engine torque to be maintained to the wheels during the shift. Basically, in a DSG, skip-shifting is rarely the right answer, it's better to fast shift through every gear.
Interestingly, when the DSG wants to go from 6th to 4th (highway downshift in cruise control), it goes 6-5-4 very quickly. 5th is essentially skipped over even though the display flashes it briefly as it goes through it.
As for GPS predictive cruise control, Fifth Gear had a segment on that recently in a Bentley.
