noob_tl
The ring gear teeth on the torque converter of my '03 NB are worn down to the point that the starter no longer engages. The trans will have to come out and the TC replaced. I've read through the 01M series by CoolAirVW and the R&R instructions on his website, and I want to make sure I get all the proper fasteners and other parts replaced.
The only ones I saw mentioned are the ones on the dogbone. Are there other ones I should replace, or any other parts I need to get on order for this? Do I need the Transmission Mount & Bracket Bolt Set from idparts, or is the dogbone bolt kit sufficient? Also, besides the triple-square (M8?) tool for the axles, any other specialty tools needed?
I don't know if the trans has ever been repaired or serviced (190k miles) so I will be replacing the trans and diff fluids. I haven't had any problems with the trans, but I want to do a thorough inspection before putting it back in.
Finally, anything in particular to look for in a replacement TC (are TDIs different than gassers?)
