What new fasteners are needed when doing a timing belt?
fatmobile
north iowa
an ALH M-TDI in a MK2, a 2000 Jetta
I went through some old posts
but when I brought the numbers to the dealership
many were obsolete numbers.
Here's what I have so far:
(check my work)
038 103 0 85C new cam seal
N 903 28504 the three injection pump timing adjust bolts, non-Stretch
N 102 09605 mount to mount, 2 of these old # N 102 096 03
N 907 12403 Engine mount to engine, 2 of them. old # N 907 124 01
N 103 28002 engine mount to engine, the long one. old # N 102 043 04
N905 96906 engine mount to body, 2 of them. old # N 905 906 02
WHT005322 Crank Bolt
038 145 345 vacuum pump seal
N 900 74404 nut 2 of these, for idler and tensioner studs??
N 014 6341 stud??
N 019 5315 bolt??????
N 101 693 03 stud??
G 013 A8J1 LDSP G13 coolant
P2B
Toronto & Muskoka, Canada
I would recommend buying a TB kit from one of our trusted vendors, that way you get everything you need without having to deal with part numbers or the dealer.
Simon
KrashDH
Washington
2002 Golf
Simon
Second this. The reputable vendors on this site have already done the legwork for you. You won't be able to save money by piecing together your own kit either
Tdijarhead
Lawrenceville PA
Here you go, one nice neat package with additional items available if desired.
94cobra2615
ohio
99 jetta tdi
Zero are NEEDED unless you just have money to burn.
I know the book says they are req'd.
Vince Waldon
Edmonton AB Canada
Hopefully you've found the A4 timing belt pdf here... one of the best step-by-step guides there is, and I believe it has the complete list of torque-to-yield bolts and other disposables.
If not, linked in my sig.
KrashDH
Washington
2002 Golf
Haha do you know how tty bolts are designed and engineered? I do. It doesn't take an engineer to understand in certain applications, you're gambling. $50 in bolts sure beats the alternative...new top end and a lot more time and money wasted. So I would say, if you ignore these, you actually have more money to burn, when something fails.
fatmobile
north iowa
Thanks Vince.
I do have that on my computer.
I just used it to verify/update the list showing what the old numbers were.
Still have several numbers from the dealership receipt
that I don't remember what they go to.
Mostly roller, tensioner studs and nuts.
The dealership did sell me some bolts that didn't fit anywhere near the timing belt.
I'm also trying to sort them off the list.
Vince Waldon
Edmonton AB Canada
Bolts related to the motor mounts are probably the really critical ones. A dropped engine will ruin your day, and it absolutely happens. :)
Likewise with rollers and studs... same bad day if they let go.
AndyBees
Southeast Kentucky
Unless you plan to change-out the Crankshaft Seal (which is not on your list), there is no need for a Crankshaft Bolt.
I agree with the others, get a "kit" from one of the reputable vendors that support this Club.
fatmobile
north iowa
Agreed. That first number started out as a possible crank seal number.
More likely a cam seal, from my notes.
Not sure if it's the same as the crank seal on a TDI.
I got a TDI that needs a timing belt change.
It came with a contitech timing belt kit.
These bolts aren't in it.
I'll order up both studs and see where they fit.
I think the nut is the same for both idler/tensioner studs.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
I see no reason to not replace any fasteners specified to be replaced. If your 3 IP pulley bolts are gold, not silver, they are re-usable.
Mozambiquer
Versailles Missouri
1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI
I second replacing the bolts. I had one of the engine mount bolts break on me after doing a timing belt change where I didn't replace the bolts. (Didn't know I needed to...) I then had to replace the engine mount block that bolts to the engine.
