JETaah
This is the second customer that has come in for DSG fluid service where I have found RED ATF in the trans. Neither car is showing ill effects from the use. And, if they were getting a fluid change then, it has been in service for ~ 40K miles. The most recent car is a 2010 Jetta TDI with 99K miles on the clock.
This time I was able to get some info on what fluid was used.
The shop that did the previous service claims that they use BG Products p/n 312 Universal fluid in all the VW automatics. Either they don't know that the DSG transmission is not a typical torque converter type or they just say "The hell with it. We buy fluid by the drumfull and that is what we use" ....I am not sure. The customer is now a bit worried about what might happen to his tranny on the long term from using this.
BG Products actually does make a DSG specific fluid p/n 319 and it is amber colored.
Both transmissions have wet clutches, right?
What is the difference between the two where it requires a specific fluid for the DSG?
Is typical RED ATF suitable as a differential lube?
