What is a ventectomy?
HelenaTDI
Helena, MT
2003 Jetta GLS, 2002 Golf GLS, 2001 Jetta GLS, 2002 Golf GLS & Jetta GLS(Parts Store), 2015 Passat 6spd
oldskool1963vw said:
I keep seeing peoples signature with this mod listed. What is it?
See the "How to's section". It allows more fuel to be added when topping off.
CoopDiesel
Oak Park, MI
2011 Golf TDI
Just did the mod this past weekend..really easy to do, just be careful not to drop the vent tab doohicky down into the bumper cover...I had to have a little kid get mine out for me...
NorthernMage
Victoria, BC
2012 Jetta TDI, 6MT, Platinum Grey
oldskool, the tank is the same one they put in the gasser and it comes with a "vented expansion" area in the top of the tank for all the vapours to collect in, diesel fuel doesn't do that so if you remove the vent tab you can fill that area with fuel. The tab is designed to be depressed when you put your cap back on. IIRC you can put in another gallon or two giving you another 100 miles of range.
Croberts
Baraboo, WI
Jetta, 2003, Silver
I just use the end of the nozzle to depress the vent button, takes the same amount of time as a ventectomy to fill and I still have the vent in place.
NarfBLAST
Waterdown, Ontario, Canada
2001 Golf 5MT
I have never heard of anyone regretting doing the ventectomy. And it so totally not the same thing.
If you have ever used the vent, remove the vent. You will be more satisfied with the the venting procedure than ever before.
Croberts
Baraboo, WI
Jetta, 2003, Silver
You don't understand, I depress the vent button WHILE filling. It vents as it fills, I just listen to it come up the filler pipe. Then I hold the vent button in while I top it off. Takes the same amount of time to fill as a ventectomy and i have yet to spill a drop.
NarfBLAST
2001 Golf 5MT
Yes, I did that for years, I wish I had done the ventectomy sooner.
NarfBLAST
2001 Golf 5MT
Yes, I used to vent too, I wish I had done the ventectomy sooner. I never pushed the button while filling before the vent engaged, that isn't nescessary... but I guess if you like holding your nozzel with both hands that is up to you.
