What is a PO252 code
brain99
I got a P0252 code that started with total loss of boost and possibly fuel starvation. Wont rev up and very slow to get to speed. Just driving along the highway at 50 MPH and went to step down and no power, and the Ck Engine light was set. Scan tool shows P0252 and erases but resets a minute later. Vac line look ok and starts fine. Any Ideas?
doc_m
somwhere
None
P0252 is Injection pump metering control (A) range/performance not to sure what that means myself but that's the bently definition
wny_pat
Western New York State
2002 Jetta TDI
P0252 = "Injection Pump Metering Control (A) Range/Performance"
(Opps, already answered by Doc m while I was thinking.)
Beyond that, you will need someone a lot better than me to help. Suggest you find a TDI Guru. Not a dealer.
P2B
Toronto & Muskoka, Canada
did you get that code fixed? i'm 2hrs from you and now i have that problem with a new pump
User @brain99 hasn't logged in for more than 14 years ;)
Not sure where you are seeing P0252 but I believe VCDS would report P1248:
Since you have a "new" pump this thread might be relevant - pump pulley was incorrectly indexed:
1kmiletdi
ocala,fl
mk4
i still haven't fixed this issue i'm annoyed as ****, i see the possibility of it being the N108 connection?
