Daves TDI
I have a 1998 Jetta AHU. I need an injection pump, Which pumps swap over. Will an AHL pump work?
Pretty sure seal behind pulley is leaking. Car still runs great. What Years and which vehicles have 1Zs?Ahu or 1z are the only ones that swap right over. You can make the alh ones work with some machine work and maybe an electrical connection or two. What is wrong with yours?
1z is 1996-1997 Passat TDI, ahu is 1997-1999.5 Jetta TDI.Pretty sure seal behind pulley is leaking. Car still runs great. What Years and which vehicles have 1Zs?
Here is the seal kit for the pump. https://www.fcpeuro.com/products/vw-fuel-injection-pump-seal-kit-bosch-2467010003000 It's probably the top seals, which you'll need a t30 torx and the special triangle socket to do. You'll also need vcds for setting the IQ. There's a nice write-up for that somewhere around here. The back seal is even harder to do, though not impossible. It's best to do on a workbench though, as it would be really hard to keep from dropping the shims. It's hard enough on the bench. I just did my first, and it slipped down... Well, you live and learn.Great news!. Not seal behind Pulley. The diamond shaped plate on back side of the pump has a drip. Anyone know what size Tourx bit it is and where to get gasket?
Yeah, I know which part that is. Not sure what it's called.I have that kit but do not see the gasket for that back plate. It is almost a diamond shape but instead of points the ends are rounded I guess you could say oval shaped with two torx bolts. I will try to get a pic of it. When I say back of the pump if you are looking at pump towad the block.
