Just a little update here
. I cut the center out of the flywheel the other day so I could get at the bolts. A cut-off wheel made fairly quick work of it. I stripped the rest of the parts from the block. Everything was going along just fine until I pulled the #3 Main cap. The journal is distorted and the bearing shells show some major damage. The lower shell has large sections missing from the middle of the bearing and the upper shell is beat down and mushroomed over. The shells are loose within the cap. With the setup I have I was able to measure .003" run-out on the journal in one area. My tooling wouldn't allow for an accurate measurement across the journal, so I'll have to wait until the machine shop meaures it to fully understand the extent of the damage. The other journals and bearngs show damage/wear as well, but not near as bad as #3. They however don't show any run-out.
I cleaned everything up today and I'll haul it all to the shop tomorrow.
My mind is set on an 02A 22lb flywheel and a South Bend stage 3 street clutch.
The cylinder bores are all well with factory specs so the shop will just hone 'em. I still haven't mic'ed the pistons yet, but so far I see no reason to toss them.
After seeing the #3 journal and noticing the oilpan was replaced I'm not convinced that the timing belt broke. Now I'm wondering if the engine ran out of oil when it smacked the pan. It seems to explain the observed damage better. I'll still have the rods inspected and rebuilt as needed.
I'm selling off most of my gasser parts so the toy fund is growing. I have a line on a few flywheels now and hope to be ordering rebuild parts and a clutch kit by late next week.
I like the Cat yellow on my previous engines, but I'm thinking Lime Green for this block.
There's more pics in the album.
