FlexYJeeper
Hello Everyone!
An old Mercedes Diesel has always been a dream car that i wanted to own at some point in my life however i dont have much money but have a lot of time and patience. i like buying things other people would consider junk and fixing them. probably costs more in the long run but at the end i know what i have.
a few days ago i picked up a W116 off craigslist for very very cheap. this is what i was greeted to.
it was apparently running when parked 4 years ago
got it loaded up and realized its almost the length of my F150.
and finally home
today i was finally able to play with it. hooked up cables to my GTD and tried to fire it. wasnt getting power to anything. i pulled the battery mount out to find the negative ground to the frame was badly rusted and wasnt making contact. wire brush+sand paper+new bolt and i had power to the dash. however there is still no start. i pulled the downpipe off the turbo to get top side access to the starter where i found i was able to jump the solenoid with a screwdriver. when i did the motor turned over very slowly. unfortunately my volt meter is dead so i couldnt test the signal wire to the solenoid to see if it was getting power so im not sure if its a bad solenoid or fault in the wiring. the slow turnover also has me concerned. need to check voltage to starter. if the voltage to the starter is good i will pull the starter then tear it apart to give it a good cleaning. really dont want to spend money on a starter.
and thats where im at as of now. going to be busy until sunday but if anyone has any ideas for me post them up!
and finally home
