VelvetFoot
I am about to attempt to change front and rear rotors and pads (the rotors have 185k miles). Anything else I should do? Thanks
All good advice. I just replaced the rotors (all four) on my 2000 Golf after 130k miles. Everything was in good order but those guide pins were dry!meganuke said:Check the boots on the sliding pins for cracks or tears. Lubricate those pins. Look for corrosion or dirt around the piston. Clean any debris out with a toothbrush. Inspect the brake lines for cracks or dry rot.
