What did you do to your Audi TDI today?
Nero Morg
OR
Did my first service; oil, air filter, fuel filter, cabin air... Dang that fuel filter panel is annoying to take down. 54,500 miles.
RexNICO
South West OH
2011 Tiguan (13 Jetta sedan eng/trans)
I'm guessing that means the A6 fuel filter is under the car, not in the engine bay?
Any special steps to make sure the filter gets filled?
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
Yes - under the passenger side. Car is pretty well covered front to rear with panels and multiple have to be removed to get one out. VCDS to prime for me.
Nero Morg
OR
Yes, under about where the front passenger seat is. Lots of 10mm plastic nuts that hold the aero plate on. As for swapping the filter it was just R&R the fuel lines. Wasn't too bad.
I didn't use VCDS to prime, I just keyed on and off twice, fired right up.
RexNICO
South West OH
Replaced head light HID bulbs. Fairly easy, but of course the passenger side connector was less cooperative than the drivers side. And that was the bulb throwing the error.
I would say, Audi greatly improved the serviceability I this area.
Of course having the error go away and it not returning was a nice benefit.
RexNICO
South West OH
(Over the weekend) - finally got the wipers working again on our silver Q7, a combination of shipping delays, priorities and the car was still drive-able when it wasn't raining/going to rain.
crashtested
Nelson, BC
2016 Q5 TDI Technik, 2014 GSW CL 6MT (RIP), 2004 Jetta GLS 5MT (sold), 2010 GSW HL 6MT (buy back)
Mods could this be a sticky for this forum??
I called Audi to inquire about transmission service & a FF change. Got an automated email saying my appointment had been canceled before the service coordinator’s email explaining why lol seems the one service record I didn’t have had the FF change at 82k km.
New to Audi & the Quattro drive system I find that the tranny feels like it slips a bit when you 1st start the car and go from P - D or from a stop, once it’s warmed up there is no hesitation off the line. That’s why I had asked for a transmission service to which I was told it’s “lifetime fluid”. Any insights?
gforce1108
Newburgh, NY
Inc alled Audi to inquire about transmission service & a FF change. Got an automated email saying my appointment had been canceled before the service coordinator’s email explaining why lol seems the one service record I didn’t have had the FF change at 82k km.
It's absolutely NOT lifetime fluid right from the manufacturer of that transmission. I think ZF says 70k? Maybe 50K. The other vehicles that use the same trans have a change interval listed. The shift logic is a little wonky (due to emissions flash I'm told). A TCU tune would correct - I drive in manual most of the time and it is much better. Not perfect in 1st, but better.
3L3M3NT
Sturgeon Bay, WI
04 Jetta GLS TDI, 04 RTDI
Midwesthick
Denver
No more TDI's - electric now
Waiting on a new DPF and post-cat from VW currently. They ended up changing all sensors associated with the emissions but the prior parts are on back order. Can runs well but had a code pop up and got it all covered under the DG warranty.
Fixed the passenger side AC drip, added a quart of oil, and swapped out cabin filter today.
I am ready for the roasting here:
Purchased a Kerma tune - I won’t install it until the new DPF arrives. Super stoked tho.
I was curious and had a muffler shop remove the rear suitcase muffler and still keep the tips. I also did the childish mod of cutting a 4”x4” hole into the side of the Airbox and a matching hole in the wheel well so it draws the air from there directly.
Both out of curiosity and the Touareg is doing just fine and is actually a lot more fun to drive. Roast away but both were done because “why not curiosity” lol
crashtested
Nelson, BC
Rotated the summer shoes.
TurboABA
Kitchener, ON
Enabled windows "comfort" operation via fob after a lot of coding change attempts and swearing..... unlike all the other platforms I've previously done this on, the A6 needs to have the process "finished" via the MMI selections.... took me a while to figure it out.
okimavich
Maryland
`16 Audi A6, ‘15 Audi Q5
I changed tranny, front, center and rear diff fluids on both cars at about 70K. Old fluid was dark and the magnets on the tranny filter was sludged with shavings. Tranny fluid change definitely needs to be topped off at temp and with the engine running. Otherwise you will be about 1L short.
Center diff fluid is apparently liquid gold. Audi wants $100+ for 1L. I found some Ravenol TOR-AWD for a little less.
