I was running my TDI for much of this season in HS (running old street tires). Not competitive, but I managed to get a couple of trophies in Novice class. To this end, I did some research on what mods I could do.
To stay in HS, I could do the following:
Koni Yellows
R-Comps (225/50-15) on OEM wheels (since I've not been able to find any aftermarket 15" wheel that matches the OE dimensions)
5mm spacers on the front wheels (figuring a little extra track up front can't hurt)
cat-back
matched & optimized stock injectors.
...and that's about it... that tire size will drop the gearing a bit and (hopefully) make the acceleration a bit quicker (something I had problems with). The downside being the need to shift to 3rd on most courses when gassers can simply leave their cars in 2nd. Since I was usually bumping the rev-limiter in 2nd on most courses anyway and occasionally shifting to 3rd, I figured this didn't really matter.
Then I looked at possibly doing something to increase HP... and here, TDI's have an advantage most cars don't have - the ability to easily adjust fueling to seriously make more power (a PowerBox). Since this doesn't affect boost levels, it keeps the car is ST class where there are more suspension upgrades allowed, and it has a ghost of a chance of being competitive, depending on how many 89 Civics built to ST specs compete in your region. Since I have a past ST National Champion Civic in my region, I decided this wasn't worth it. The problem the MkIV has in ST is weight vs' the 225 tire width limit (at least we have more tire and wheels options here). Against a 2000 lb Civic, the 3000+ lb MkIV simply doesn't have a chance, no matter what you (can legally) do to the engine and suspension.
In my case, I have a 3rd option: run a different car. A 2007 MINI Cooper convertible in HS. I did this for the event this past w/e. While I'm still not as comfortable in the car as I am in the TDI, it has better tires (new Direzza Star Specs vs. worn out SP8000's), better acceleration and obviously better handling. While I finished about the same in Novice class, my times in HS were considerably more competetive.
Could you build a Mk IV for a Prepared class and have it be competitive... possibly... although due to the mods required, it would basically end up being a dedicated race car with poor street characteristics.
So, in the end, as much as I enjoyed the novelty of running a TDI wagon in auto-x, and I definitely wasn't the slowest car out there (my g/f was pissed when she her times in her modded '03 MCS rarely beat mine), I think the TDI is now retired from auto-x...
