PakProtector
Looking for a solid Golf hood Kirk; colour not too important...
Douglas
Douglas
AND, Sand Lake auto is just up the road a bit.There might be a mk4 with crank windows at Sand Lake Auto. It had manual mirrors I remember because I was looking for a mirror. I don’t recall if it was a Jetta or Golf. They’re open on Saturdays
I may have one - I'll check tonightLooking for a solid Golf hood Kirk; colour not too important...
Douglas
But leaving my house will be an issue. HahahaThe GTG is on a small hill so bump starting the car shouldn't be a big problem.
Also hunting the rear hatch volume cover. Parcel tray I think...AND, Sand Lake auto is just up the road a bit.
Kirk,No, back in the Jackson area.
I’ll confirm by end of week. Thanks!
Just do it in reverse then...But leaving my house will be an issue. Hahaha
Doug, I have two decent Jetta hoods (black and red), but no Golf Hoods, sorryLooking for a solid Golf hood Kirk; colour not too important...
Douglas
bummer TomKirk,
Regrettably, we’re not going to be making it after all. Thanks for organizing the GTG and I hope you all have a great time.
Perfect, thanks Mike!Kirk: Bringing lots of K & M... working on finding some relish! Costco was out. Go figure... see you Saturday. - Mike B
Do come regardless of what you have to drive...Looking like I won’t be making it tomorrow, I unexpectedly had to travel for work this week and still making my way home. If I do make it tomorrow I sadly wont be in the Jetta as I still haven’t located someone to make the needed repairs to my beloved Jetta. If I don’t see you all tomorrow I hope you all have a great time and post pictures!
I could use a truck like that.Great day, great people. Fun all around. Thanks for hosting this Kirk..
I'm glad that you listed your inventory. That should come in handy for us.A lengthy list of parts that will be available: (assume MK4 unless noted otherwise) - MAKE OFFERS in Person at GTG
EXTERIOR:
- (2) Jetta Hoods - one black, one red
- (1) Beetle rear hatch, silver w/ wing
- (4) B4V wagon doors - black, rust free from TX
- (1) B4V rear hatch - black, rust free from TX
- (3) Jetta wagon doors - Indigo Blue, rust free
- (2) Golf front bumper covers, one green, one black
- (1) Jetta front bumper cover, IB
- (1) Jetta wagon rear bumper cover, IB
- multiples Jetta/Beetle headlights
- (1) pair of MK5 Jetta headlights (nice shape)
- multiples Jetta/Golf tail lights, including one candy cane striped set
- multiples mirrors (several colors)
- wipers, rain trays, antennas, lower front grill inserts
- several sets of 15" and 16" alloy and steel 5x100 rims, most w/ tires on them (at least 5 sets)
- (1) 16" alloy 5 spoke rim 5x112 with tire
- (1) 17" alloy 5 spoke rim 5x112 w/ tire
- (4) brand new (take-offs) Falken tires, 205/60/16 Sincera SN250
UNDER THE HOOD engine bay related (assume ALH unless noted otherwise)
- multiples - plastic belly pans
- (2) DG alum panzer plates, one side skirt
- (1) good radiator core support
- (2) cooling fan sets
- multiples of assorted engine top covers (FREE, take one) -
- TDI frost heater
(have multiples, all of these items listed below are sorted separately into bins)
- valve covers
- timing covers (both lowers and uppers)
- TB backing plates
- accessory brackets
- fuel sending units
- battery trays, battery covers
- CCV pucks and hard pipes (some NOS of pipes)
- coolant reservoir balls
- coolant hoses/fittings/pipes
- EGR valves
- EGR coolers/pipes
- PS hoses/lines & PS pumps, PS pulleys
- hard intake pipes, air box accordian pipes and airboxes
- IC hose and hard pipes
- vac pumps/brake booster
- IP sprockets, cam sprockets
- injector hold downs/bolts/washers
- injectors
- turbo related pieces, heat shields, brackets
- Intercoolers
- Alternators
- Starters
- engine mounts/brackets, trans mounts/brackets
- battery cables
- ECU's
- lugbolts (like you read about)
- centercaps up the wazoo
INTERIOR
- misc tidbits
- instrument clusters
- (1) steering wheel
- airbags
- cargo mats for NMS Passat trunk and possible MK7 GSW
- (1) Q7 cargo area roller shade
- bin full of window requlator good parts, and also a new rear pass door lock module (NOS)
- misc 2010 Jetta tidbits, including a good working radio (1KO 035 180 AC)
- a couple of NMS Passat heater cores (new)
- Full set of black leather Jetta Door cards
