Well this is a fine mess, could use some direction
lowlife
Mn
03 jetta 13 passat
Ever want to kill a family member to death? Passat got jump started but sounds like it was first connected with cables reversed. Anyway it made it back from KC somehow. Alternator charges not sure how diodes are. It runs normally so I guess I will call it a win. No radio nav etc. First time I ran the codes and drove it 15 miles there was no codes for steering or tpms. No expert on the Vag com here but it would seem that we start with a battery, it is bad. I had it on charger for diagnostics. Also looks like a Can gateway may be in order as well. Thanks in advance for any help. I will learn and pass it on here as I have tried to do before.
VIN: 1VWCN7A31DC123713 License Plate:
Mileage: 124650km-77453mi Repair Order: battery ooops
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A31DC123713 Mileage: 124650km-77453miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI X24 9982
Revision: 71X24--- Serial number: CVN: D240C61F00000000
Coding: 001D0012042400008000
Shop #: WSC 02402 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B753953B2BA485154-806E
VINID: 0669D37874430544C10831C10C34B4B8BF
No fault code found.
Readiness: 0 0 0 X 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9436
Revision: 05651213 Serial number: 00001301260226
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 2447E22FE70417A905-8070
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492400FDA31203E5921C0042A71000
Shop #: WSC 09003 957 00200
VCID: 7DF1F74BE42E86612A-8028
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Time Indication: 0
Date: 2016.07.10
Time: 19:28:42
Freeze Frame:
Count: 2
Count: 12
Count: 4096
Count: 16390
Count: 44544
Count: 0
Count: 509
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0197656923
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 3467126F9FE4872995-8060
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 561 907 044 R HW: 561 907 044 R
Component: Climatronic H03 0405
Revision: 00001K01
Coding: 0010001012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 2643F8275938E5B91B-8072
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B982B08D408880201360085480071008645A005F064806000BC70
VCID: 74E7D26FD764C72955-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 240113 05 54 0403
Coding: 22300A
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM0160BB
Coding: 00004D4A
Shop #: WSC 26369 002 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75E1EF6BD41EDE2162-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y130000S2D00E
Coding: 303047
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME040E6576ZZZZ
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME1A276476ZZZ.
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME250B5E22ZZZU
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME20585722ZZZL
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME6E3B5A21ZZZ3
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME7F065A21ZZZ+
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130130302343
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DF1F74BEC2E86612A-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 1C37DACF17742F69BD-8048
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 16031303290196
Coding: 461000
VCID: 76E3E867C118D5396B-8022
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Time Indication: 0
Date: 2016.07.10
Time: 19:28:47
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Time Indication: 0
Date: 2016.07.10
Time: 19:28:47
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Time Indication: 0
Date: 2016.07.10
Time: 19:28:47
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADBCC178DA001D9FF-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000002866005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 306F1E7F6BFCBB09F1-8064
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000052126339
Coding: 00581B0000000000000021010100202020202120202020
VCID: 60CFAE3F739C4B8921-8034
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0006330208
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630130318131651
Coding: 800000
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Date: 2022.02.17
Time: 19:28:40
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Date: 2022.02.17
Time: 19:28:40
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 377D256346926C31B0-8062
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 124652 km
Time Indication: 0
Date: 2016.07.10
Time: 19:28:41
Freeze Frame:
Battery Volts: 12.6 V
DD
Temperature: 18.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0031288
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FEDDD03BE42E4F1A8-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011230900460
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0006349040
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D31D7CB0C6E26614A-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631130315113947
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Date: 2022.02.17
Time: 19:28:40
Address 56: Radio
Cannot be reached
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664332807
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A7B3C57BD8071594F-806E
1 Fault Found:
0022 - Radio
U1066 00 [009] - No Communication
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 124652 km
Date: 2022.02.17
Time: 19:28:40
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
First is get a good battery in there. Low voltages can show a host of errors. If you can't remove it and fully charge it, then get a new one. Batteries don't like being discharged completely and it isn't good for the alternator to try and fully charge them either. Then drive it some to let any thing clear and check again.
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
Too much drama.
Save your scan results from above.
Clear all codes.
Charge your battery, have it tested if necessary.
Restart and see which of the codes come back.
Then start troubleshooting one at a time.
I don't see anything that I'd panic about.... not at this point anyways.
lowlife
Mn
03 jetta 13 passat
I'm going to get a new battery and will go from there, thx for help. BTW family member is still alive and happy......kinda
lowlife
Mn
03 jetta 13 passat
Appreciate the help so far. All fuses are good including mains and branch fuses including under hood and drivers side dash. Checked with ohm meter not visual.
No change new scan with new battery. I believe I am unable to clear codes. Right after I try to clear it comes back with the same codes as before I clear without me trying a rescan if that makes any sense. In other words the module numbers come back with the same faults without me scanning. That should make it clear as mud.
Am I correct in assuming my next step is to buy a can gateway? If so is good used ok, is there different ones, do I need to recode and about 10 more questions. I will research and probably answer a lot of these questions. Thanks
jjblbi
lbi, nj
2014 Passat SEL TDI
I bought my son a used gas Tiguan from a Nissan Dealer about 18 months ago. We took our vcds and laptop to scan and negotiate the price. The scan revealed just about every code under the sun. I tried clearing with the "clear all codes" button and they all came back. Dealer claimed car had sat for a while with a dead battery and they just replaced the battery. I went back in and cleared each code individually then we test drove the car for 15 minutes...no codes and none since. Try clearing each code individually. Good luck, John
lowlife
Mn
03 jetta 13 passat
Not quite sure how to do that john but will research. I am a novice on the vcds. Grasias
Update. No love, most controllers can't be reached If nothing else I will be forced to be "smarter" because of this mishap.
Say can the optical bus diagnostics help in my situation, looks like it may be able too. Nope tried not supported
Off topic but I need to see if I have the scope function.
lowlife
Mn
03 jetta 13 passat
Am I correct that the can gateway is the highway through which all controllers must travel
pedroYUL
MI, USA
2004 wagon BEW; 2015 Passat CVCA; 2015 GSW CRUA
But your CAN gateway is only complaining about not been able to talk to the radio. I say disconnect the radio and try scanning and clearing codes.
lowlife
Mn
03 jetta 13 passat
I would say that is reasonable. If that worked though I would assume either several modules would need to be replaced or the head unit itself.
Then I would need to deal with the other modules that have no communication as well. It was previously scanned about a week before all this happened with no codes.
Is there a good article I could read that will explain how all this works together? Google has not been my friend. I have lived under the phrase of " Design, function, repair. Im having a time with design and function. Again many thanks just remind yourself it's like teaching a toddler to walk
pedroYUL
MI, USA
Also, check the fuse for the headunit, make sure that didn't blow. I presume your backup camera is not showing anything in the screen, and the HU is not even powering up.
What others have said before is true, many times some codes are not reset with the "clear all codes" command. Try going inside the modules that are "talking", get in the gateway module and clear the codes in there, and so on.
lowlife
Mn
03 jetta 13 passat
I did get into the gateway and cleared then rechecked. Everything came back the same. I think I tried getting into the ones that wont communicate but not 100 percent sure, last few days are a blur with work. Will attempt again to make sure
The head unit won't power up. I will also disconnect the unit but my question is would communication work then if it was a bad HU and just send a different code. Lots of questions.
Checked all fuses at the box with a ohm meter. All in good shape unless there is another one not under the hood or on drivers side dash
What can prevent the gateway from communicating with the other modules? Bad wiring or modules, fuses, bad gateway, bad devise (headunit etc)
I just automatically assume ( right or wrong ) that if several things occurred at the same time look for the common denominator. I understand that this is a bit different in that several things could have been affected at the same time as it electricity.
pedroYUL
MI, USA
Reversing the battery can fry multiple things, but the can gateway is talking. The HU seems fried or again, you haven't found the right fuse. Yes, there is another fuse box in the cabin, I believe you have to get the little swing door (below the light switch) out of the hinges and it is right there.
I forget if this particular HU has a fuse in the back, perhaps that's the older ones.
Most of all codes are for the headunit, which might be indeed dead. Other than that, all windows missing calibration is solved by going full up and full down couple of times using it's switch, not all from the drivers switch. The abs, not sure, perhaps that sensor got fried.
jjblbi
lbi, nj
2014 Passat SEL TDI
I don't have vcds open right now but I think at the scan results, just below the VIN where the modules are listed numerically with their status, ones with malfunction had red text. Either a right click or double click brought up a dialog box asking if you want to clear the code. Click OK. You have to do this for each fault and can't batch "clear all codes".
There is also a Ross Tech Wiki page which may help. I must confess I am by no means a VCDS master. Good luck, John
06bluebeetletdi
Middlesex, NC
Have you driven it at all? If it was an early 2012 before the master fuse then i could see multiple modules being fried, but later ones (later 12s and up) seem to just fry the master fuse.
lowlife
Mn
03 jetta 13 passat
2013 not near it for the build date though. Master fuse by battery checks out ok.
I tried clearing codes indivually but either wasn't possible or they came back with a rescan. Car runs down the road fine.
Plan to try to pull rns510 this weekend to disconnect and check for a fuse. Seems like it may or may not have one on the back of the unit.
06bluebeetletdi
Middlesex, NC
Early 2012 meaning built in 2011. I saw an early 2012 passat in a dealership service dept one time that autozone installed a battery backwards, you could smell the fried electronics final bill iirc was around $12k, this was 2014ish so the car was fixed and not totaled but it took awhile. Later 2012s and newer have the master fuse which prevents that kind of damage.
lowlife
Mn
03 jetta 13 passat
UPDATE
There is a 20 amp mini fuse in the back of the RNS510. Was blown, replaced, works no codes. I wish to thank every response here. Hopefully anyone that needs this info may stumble on this thread.
Now to tackle the steering assist which may be a reset procedure and TPMS module. Like i said these were not on with my initial test drive. They came on later in the day.
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
UPDATE
Glad it all got sorted out for ya
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
UPDATE
So a fuse in the stereo save it, thats neat. Glad you figuring it out.
