spdracr0
A true racer would never worry about his exhaust rusting over a performance advantage.....remember exhaust can be replaced later, wins are forever..
To a point, yes. But here is the kicker... as you create the expansion chamber effect, if you slow and/or cool the exhaust stream flow beyond critical point, you create a high pressure pocket that acts as a restriction in the pipe... like a blockage that causes additional backpressure to build for the exhaust stream to push it out of the pipe. The critical point varies according to the heat, velocity and volume of the exhaust stream as well as the change in size and shape of the pipe.M I N I O N said:I forgot to add one details. After about where the cat normalls goes, my 4" exhaust is getting remade out of aluminum. Instead of welding, the exhaust will dissipate more heat and make the gasses more dense the further they get down creating a siphon effect and improving spool times.
You mean about 1/3 as much...M I N I O N said:It also naturally weighs a tenth as much.
IndigoBlueWagon said:I will put in a roll bar, and I won't scrimp on its construction. But keep in mind that the rollover protection in a Rabbit is vastly different than a MKIV Golf. As I posted earlier, part of the appeal of the Golf is the strength of the structure.
Sounds to me like you are ready for this:DbLog said:The thing probably would have flipped if my 150lbs wasn't weighing down the right side.
Got Bearings? said:Sounds like that "snow" stuff is cold.![]()
If you have track days in the cold, then keeping the heater stuff is a good idea. Even if it's 10-20-30 lbs, the alternative is extreme discomfort or no track time. Not a good trade off in my opinion.
I mentioned removing the dash because you can always find something behind it to remove that you don't need. When you remove that stuff, you can then remove its wiring as far back as you can trace it. Wiring adds up quick. There might even be a brace behind the dash that you can remove.
Don't forget speed holes!![]()
Actually could probably just install the coolant flange from an Automatic trans.GuyGuy said:I know this is small stuff but you could also remove the three glow plug coolant heater coming out the driver side of the head.
good one!!whitedog said:Actually could probably just install the coolant flange from an Automatic trans.
Hey, I need one of those!!!whitedog said:Actually could probably just install the coolant flange from an Automatic trans.
