ChuckV309
I am not getting full boost pressure on my 1996 B4V. It appears to be due to the VNT spring being weak and allowing the boost to be released too soon. I have checked all parts of the pressurized system and everything is good (N75, hoses, etc), but can only get about 12 psi. I have new DLC 1019 injectors and tune from KermaTDI. From working with Charlie from Kerma, he feels the problem is the VNT spring and recommends putting on a new turbo.
When I put pressure to the VNT it starts to move at 5-6 PSI and is at full travel around 9-10 PSI.
My question is can I do something other than a new turbo for a while til I get the money for a turbo? The car drives fine, just not getting full boost for the tune and injectors when at full throttle. I was thinking about using some kind of pressure regulator to control pressure to the VNT. Like a small one used to control air pressure to an air brush. I know it would be trial and error till I get it dialed in to limit pressure to 18 psi. The cost would be $0 as I have a mini regulator I could steal from my air brush for a while.
Any ideas or suggestions?
Chuck
Chuck
