Way thru firewall on 2009 Jetta TDI?
TangoMike
Ohio
2009 Jetta TDI Sedan Manual Trans & Nav
I need a way to get two 8 gauge wires from the battery into the interior. Any chance someone knows of an extra plugged hole or hole with some spare space?
If not thru the firewall, any chance there is something underneath?
dieselmike
Kyle, Tx
2009 Jetta
Found way through in auto Jetta
If your Jetta's an auto, there is a rubber plug where the clutch peddle assy would go. Just pull back on the sound insulation where you see four bold studs to the left of the brake and you will see a rubber plug. pull back on it and one can drive a Tata through it.
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
Hole in firewall
TangoMike has a Manual transmission.:eek:
twowheeletex
Las Vegas, NV
2009 VW Jetta TDI
I just installed my sub. 2009 jetta TDI manual. here is a pic of where to run through.
I am assuming they are or sub woofers, so I'll add some other things I learned and pictures that might help you out. if I'm wrong about the subs, maybe someone else will find it useful.
you remove the battery. then follow the wiring harness back to the firewall. there will be a grommet there. the grommet will have some nipples on it. grab one and hack it off. a pair of scissors will do fine for this.
you will have to go on the inside and remove the black plastic panel that is above your pedals. 6 or so torques. 10 or 12 bit side. again find the wiring harness and move the sound deadening material out of the way.
don't bother taking off the kick panel where the hood release is. it's a PITA and unnecessary.
then back on the outside of the vehicle again push a length of 20 guage wire through the hole where you removed that nipple. tie it to the 8 guage wire and pull it through. I used 4 gauge wire so I know it will work for four. let me know if you have any other questions.
I'll put in a couple more pictures. they might help.
I had a spare post on the power buss so it was really convenient. lowes has a lock bolt that will fit right on there.
there is a ton of room for wires in there, and the battery really hides everything when you are finished.
I ran mine under the panels by the doors. remove and install is a cinch and ir's pretty much a straight shot to the trunk.
