Festa
It appears on my 5 pot pd with a gt2262v hybrid I'm able to still produce boost and decent power up at 5000rpm and since the engine wants to rev I do and it's up there quite frequently. As the clutch is slipping and the engine is being pulled I decided to do a compression test as I had found cylinder five heater plug wet and wet on the inlet port fuel rail has held pressure so I don't think the injector seals have gone.
It could be a dribbling injector but why would it be wet on the inlet port? The compression test has shown that cylinder 4 is down and 5 is even worse ...1=430....2=435....3=475....4=360.....5=260. Psi
One theory would be that 4-5 has suffered damage from reduced circulation of fluids as both the water pump and oil pump are bias to cylinder 1 I'm so seeing if waterless coolant could or would have helped reduce the possibility of heat damage.
As I like the five pot I don't really want to scrap it but to now gain more power I may not have no choice.
Input greatly accepted
