Thanks for the response guys, if there is no seperator in the '05 PD B5.5s, then why does the manual list it as a maintenance item...(I guess its another case of VW providing not too accurate info).tomo366 said:There is no water seperator on the 05-5 06 cars, Don't Bother
Alright, now I need help being pointed to the fuel filter replacementbigEZ said:the b5.5's do indeed have water separators in the form of a white stopper on the bottom of the filter. to drain, you need to remove the filter from the housing and open the stopper, draining into a clear jar. and contrary to what some newbies think, the water "separator" is not a place where only water collects; it is just an opening to drain the fuel filter. water, if present, will appear as clear drops that do not mix with the diesel in the jar.
do not bother with draining the water separator. unless you are fueling at very seedy places, you will not find any water. just replace the filter every 20k.
That is wrong. The 2005 Passat Wagon has it. Its on the bottomof the filter (hard to see).tomo366 said:There is no water seperator on the 05-5 06 cars, Don't Bother
My Mistake!! I sold my B5.5 Passat and yes it has a Drain valve my new A5 Jetta does notSmokerr said:That is wrong. The 2005 Passat Wagon has it. Its on the bottomof the filter (hard to see).
You have to undo clips and such, lift it up to drain. A bit of a pain, but it can be done.
