kb1968
So saw coolant leaking from the normal spot a water pump would leak (under the front of the vehicle directly inline with where the water pump is) Bought the kit from dieselgeek with the metalnrd tools. Started this morning put the lock carrier in the service position removed the belts and got to removing the 6 mil allens holding the pulley to the crank sprocket. And thats where the problems began only one of the bolts will come out and the other three are so worn the F out from where someone else had removed them and not replaced them before so now i have 3 completely stripped out bolts left and I cannot get them out with everything Ive tried...ez out screw out, taps, damaged bolt removers and they are too close to the center 19 mil stretch bolt to get a good enough grip on with vise grips or anything like that. Ultimately my question would be if i remove that 19 mil bolt what happens? I am a diesel mechanic by trade but this little thing has given my a ton of problems but I love it too much to let it go. Any help would be greatly appreciated.
