If you want to use some ECU signal, I would use a control strategy that opens past a certain threshold of N75 duty cycle instead. But this would require a separate box because the raw N75 signal for VNT engines are highly dynamic
and opens up at useless times as far as WI is concerned (e.g. lift throttle), so more intelligence and logic are needed.
{Edit: Recalling Fix_Until_Broke's thread some interesting plots showing N75 duty cycle, I got mixed up as to vanes closed/open during lift-thottle while shifting}
EGR is disabled at high load, precisely where you want WI. On the other hand, could one overwrite the EGR map and replace it with a WI map and use N18? Ostensibly yes. If actually possible, this would be ideal, that is, assuming that your car is for off-road purposes only...
Looking at where WI does any benefit, it's at high RPM and high load. More directly relevant to probe and use to trigger WI are smoke/torque limiter maps.
Otherwise, a strategy based on EGT/EMP would make the most sense.
