I've recently been through and solved (I hope) multiple sources of water leaks into the B5 wagon.
Was one of the major contributors to the wiring issue which caused my CCM to die and kill pretty well all of the power accessories.
So... Imma going to list and list solutions for the leaks I have found - feel free to add your own.
I am now looking forward to fog-free windows this winter.
My leaks:
- Backup of water due to clogged drain under the battery
- Water leaking under the grommet under the brake booster (repurposed for the clutch master cylinder line in my manual conversion)
- Leaking into the HVAC and passenger side due to a rotten hvac filter sealing surface on the cowl
- Leaking into doors and into the car via a poor seal at the window regulator mounting plate in 3 out of 4 doors\
- I did not personally have, but want to mention sunroof drains - very common.
I'll be digging up pictures and posting fixes over the next little while.
My leaks:
