Apparently, the first TDI came in the 1989 Audi 100. However, I am not sure if that pump was electronically controlled. Come to think of it, I cannot think of an earlier VW that came with a drive-by-wire accelerator system (there is technically not a "throttle" pedal in a TDI).
Is this correct?
Old parts catalog I have when selecting "Other" market shows the emergence of the 1T engine code, 2.5 5 cylinder TDI with electronic pump, as showing up for model year 1990. Likely introduced in 1989 but wasn't actually in production until 1990.
Looked up part numbers and illustrations/photos of pistons, which have the direct injection combustion chamber in them, injectors, which are the clamp-in style direct injected setup instead of the threaded in IDI, no pre-chamber in the head, electronic injection pump and, yes, throttle by wire. Sensor on the pedal, no cable going to the pump.
This old copy of ETKA also indicates the engine was only in the Audi 100 for a single calendar year. It's "mounting time" was 01/90 through 12/90. Want to talk about a unicorn, especially at its age. It was rated at 120 hp from the factory.
The Audi 80 had the 1Z 1.9 4 cylinder from 09/91 through 07/95, other models didn't seem to get it until 1995 mostly.
There's a VIN split in 1991 where the early 91 Audi 100s got the 1T engine, the later ones replaced it with the 115 hp AAT and ABP engine codes, still 2.5L displacement. There also is a normally aspirated 2.4L AAS code engine, 82 hp, which is still a mechanical IDI diesel.
Well, this has been a fun fact-finding mission. I had heard of TDIs "being introduced in 1989" before, and that it was the 2.5 5 cylinder, but never had the full facts staring at me in the face or what the engine codes were, outputs, and I assumed and just now confirmed that yes, even those earliest TDIs were all DBW with an electronically controlled pump for fuel quantity and timing advance.
