Number6
I was replacing the rear stub axles on our 98 Jetta. Part No. 305 501 117 1. I obtained a pair from a reliable online vendor. One side went together fine, on the other side the outer bearing would not fit on the axle. (Neither would either of my old outer bearings.) The vendor sent me a replacement for the defective axle, and the outer bearing fit, but the inner did not. (Neither did my old inner bearings.) The customer service person at this vendor was not sure what brand these are; they seem unmarked as to brand and country of manufacture. One was made or inventoried in July 2008, and they have slight differences indicating different manufacturers or production runs. I then went to a local auto parts place and had them get two Febi axles in, along with bearings -- just in case something was odd about my bearings. None of the bearings fit the Febi axles, not the new ones they had, not my new ones, not my old ones. But all these bearings fit my old axles. The Febi axles say Germany, but also have a sticker on the box saying China. I ended up reusing the better of my two old axles.
So if you need to do this job, make sure to get bearings at the same time and have the vendor verify that they'll fit before shipping; or if you buy local, take your bearings in with you and check the fit. According to what I've just experienced, 80% of these axles are junk!
