Wanted: MK4 suspension (rusted, worn out is ok). Seattle, WA
02AutoWag
Snohomish, WA
2002 Jetta Wagon (5-speed swapped)
I would like to salvage the suspension pieces from my car before I call PickNPull to haul the carcass away. I am looking for your worn out or rusted pieces of junk suspension (shocks, struts, and springs). Any pieces from a Beetle, Jetta, or Golf will work for my purposes. I am located in the Seattle, WA area. Please let me know if you are looking to get rid of yours. Thank you.
JDSwan87
Black Swamp Thing
Michigan near Toledo
2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
Do you think PNP will haul the car away in that condition?
Only 1 way to find out! They might give you a little less if they see it but they are buying a junk car. They probably care more about the catalytic converter and battery than suspension components. Around here you make a call, they show up with a check, hand it to you and haul it away.
02AutoWag
Snohomish, WA
Haha. The car is minus engine and minus transmission. PNP says they’ll cut a check for $20 (twenty).
I’m more worried about the driver not accepting a car with proper suspension pieces and causing himself more work to drag it onto the deck if/when my wooden blocks fall apart. Hahaha
