WANTED: Bosio race 683 nozzles to fit v6 tdi engines
diffas
Finland
B5q A4 Avant 2.5TDi+, B7q A4 Avant 3.0TDi
I did manufactured my own springs back in the days. I can make those if there will be enough people interested about them.
The thing is to have good valve control when going up in rpm and high boost/emp levels. Never a bad thing to have.
there is no problem fitting hx35 but I'd rather put something different. I had pretty good life with garrett. GTX2967R with 0.64 iwg has decent spool.
Otherwise some gtb series big hybrid. Also I highly recommend to upgrade fuel supply system and I feel like it needs really heads to be ported if targeting that power level. I think user @Knightboat has some nozzles left?
Melker
Sweden
Audi a4 2.5tdi Quattro
Hi. I have an audi a4 b6 2.5 tdi quattro. Engine code ake. if I want to get 300hp which nozzles should I use.
adamss24
Great Britain
I started making a few sets of exhaust manifolds when I was in um- I have had stainless steel exhaust flanges laser cut about 10 years ago...couldn’t be really bothered as there seemed to be little interest in these at the time...
IltonTavares
Brazil
1.9 alh
That’s logical. AFB have big differences in construction! The nozzle needle top is 0,3 mm lower than AKE/BAU
Hello dear friend, would you mind of sharing the number of this injector holder ? The one from AKE/BAU .. I need a set of them, however they need to be 2 springs. Thanks
CaptainFaulsack
Germany
2.5TDI V6 BDH
Has anyone some Infos about stronger head Bolts now? Back in this theard Somebody talked about Passat biturbo head Bolts but Not more Infos....
