Shaggy
I am in the process of planning a swap from an auto trans to a manual in my 2003 VW Jetta TDI. I need the trans, clutch system and all related parts to complete the swap. I am interested in top quality parts from low mileage cars. So if I read the threads correctly, I pretty much need the following...
Cash in hand, ready to buy now.
- 5-speed manual transmission (Code DQY, EBJ, or EGR)
- Transmission UPPER MOUNT ONLY
- Shifter Box & Linkage
- Misc., all clutch system parts (Flywheel, Pressure Plate, Clutch)
- 2 switches on pedal + both sides of connectors and pigtails
- Clutch Pedal Assembly and Lines, clutch master and slave cylinder
- wiring harness stuff: all pigtails (3) Two to clutch pedal switches, One to reverse switch.
- Starter (different with 5-speed)
- Power steering line (different with 5-speed)
- all brackets associated with the above parts, any other minor MT associated parts, All Bolts and nuts, clips, brackets, etc... Some examples are -
- V plate between clutch and brake pedal
- Clutch pedal firewall gasket
- Small Clip on Master cylinder
- O ring for Master Cylinder
- 350mm Hose to Hydraulic Tank 1/8"ID
- Trans. mount bolts (3)
- Drive shaft bolts (12)
- Transmission input shaft seal
- Transmission input shaft O-ring
- (3) M8 Nuts that hold clutch pedal in
- the Dust "tins" plates between the MT and engine
- Transmission dust cover plate (manual)
- Engine dust cover plate (manual)
- (2) dogbone stretch bolts to subframe
- (2) upper mount stretch bolts
