want to tow with 2014 jetta TDI w/DSG Malone Stage 2
Paulman
North Carolina
2013 Jetta TDI (buyback at 109,000miles) 2014 Jetta TDI 59,000miles
Where is the best place to find this hardware?
Thanks,
Paul
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
If you want the best, get the OEM ROW solution from Westfalia
5C6803881
Used euro market would be your best source as I don't know if you can find it on this side of the pond.... unless someone already had it and it's selling as used ..... but there are plenty of aftermarket or custom made solutions too, depending on your budget and preference.
lemoncurd
Vancouver, WA | Willimantic, CT
MK6 Jetta SloWagon TDI (Golf Varient)
Westfalia is the best for our cars. Just please be careful and do not drive it like a slushbox auto. I would drive by manually selecting gear to MAKE it start in first and make that clutch fully engaged ASAP. Then keep RPM at a minimum of 2k if any load is being applied.
Best of luck
Dannyboy
Mb
2014 malone stage 2 + DSG tune. Westfalia kit. Soon to have rawtek also. Pretty simple, put it in sport mode and drive. You can drive in manual mode if you want.
Also snagged a deal on Amazon with a rear airlift 1000 kit for $93 cdn/ $73 USD. Waiting til spring to install
Savageman69
ontario
2012 Highline Touareg TDI
where did you source the hitch id like one
Dannyboy
Mb
I've sourced that from the UK. Wasn't cheap to deliver. In fact delivery and charges cost more than the kit. Wasn't sourced from VW so it doesn't have VW part number so I can't comment but it is specific model by westfalia and doesn't fit anything else.
Looks like 5C6803881 is the excat same kit.
Haven't seen any in a while.
Also you do have to make a cut in the rear bumper but it doesn't bother me.
