I have a 2015 tdi sportswagon which is my daily. I want to make more power while still being reliable, and not needing intercoolers and all that, plug and play for the special turbo noises and faster spool:}
So here are my ideas,
1. CR170 with stage 2 tune
2. gtd1456 turbo with custom tune and darkside chargepipe.
Open to everything
> CR170
no
> GTD1456
also no.
frankly, oilhammer is right. if you only want to go fast, and do "cheap" mods, get a GTI.
but these tdi's are expensive to make good reliable power.
if you want more info read through these threads:
In the future the CP3 HPFP seems like a no brainer to incorporate/upgrade. Where do I get a "KIT", how much and how difficult to install? How long do CP4's last? (I know there is no real answer but thought I ask) I do use 6 oz of Opti Lube per tank fill. Turbo CR170 upgrade, again where do I...
forums.tdiclub.com
Does anyone know if the CR170 exhaust housing has a larger aspect ratio or physically allows more exhaust gas flow? You can purchase CR170 Hybrid turbos that have been retrofit into the CR140 exhaust housing. But if the CR140 exhaust housing is even smaller than the CR170, the EGTs would be...
forums.tdiclub.com
TLDR if you want the "just trust me bro" is:
dont tune with anyone offering "stage" tunes for TDI's
buy a GTE2260, buy a CP3, do the exhaust, upgrade the IC.
that would get you a knock your socks off build. pop some injectors + headbolts in and you have a 300-330hp daily driveable reliable TDI.
