FWIW + IMO if i were you maybe you should run over the techs foot as he/she is lazy for not getting it to 0 unless something is bent, the toe should be at or very close to 0, same setting both sides. IMO if not it will zig zag.
I'll see what he says today. I hate to argue with mechanics because I take a car to them because I assume they know better than me. But looking at the spec sheet for alignment, you think he could have got the numbers to look better?FWIW + IMO if i were you maybe you should run over the techs foot as he/she is lazy for not getting it to 0 unless something is bent, the toe should be at or very close to 0, same setting both sides. IMO if not it will zig zag.
I would make sure everything is TIGHT first. These really have a brutally simple textbook Mac strut front suspension, there isn't much on them to check.
Seatman is from the other side of the Atlantic, and "track rod ball joint" means the outer tie rod end.
Also, I always chuckle when people say "lower ball joint". It's just a ball joint, there is no upper on that car.
(like my brother, the plumber, who winces when people say "hot water heater".... if your water was hot, you wouldn't need a heater, would you?)
They don't always make sense. I'm used to calling it a tie rod of course because I'm Canadian. But what does "tie rod" mean? Rods that are tied together? Doesn't really make sense but I'm not going to call it something differentThere are lots of differences from British/UK/English English and American English, that's just one of them. But I watch enough Brit TV car shows to know most of them. Bonnets, LOL....
If you keep backing off the nut it will contact the outer CV joint housing, then force the ball joint out of the knuckle.Can get the nut backed off but the ball joint won't come out. I tried hammering on it as per YouTube vids but it won't move.
Ah yes thank you. I kind of forgot this part. Also the part about using a pry bar. It was taking too long so I put it all back together. Will try again soon.If you keep backing off the nut it will contact the outer CV joint housing, then force the ball joint out of the knuckle.
Funnily enough a hood or a bonnet are both for keeping the head warm lolThere are lots of differences from British/UK/English English and American English, that's just one of them. But I watch enough Brit TV car shows to know most of them. Bonnets, LOL....
I gave up trying to remove the ball joint. I tried the method where you undo the sway bar link and try removing the ball joint that way. Without removing the axle but, control arm, etc. Basically the laziest method there is?Can get the nut backed off but the ball joint won't come out. I tried hammering on it as per YouTube vids but it won't move.
Swearing and penetrating oil didn't help.
I was still driving the car. Feels really strange. I can't wait to see what happens when I get these parts replaced. It seems like ball joint to me. It has play side to side. Like grab wheel at 3 and 9 and you can wiggle it and see movement at the ball joint. Other side and other car tight as can be.
If I hit a little uneven spot on the highway it feels like the car veers off in an ever so slightly different direction and you can feel that occurring for like 3 or 4 seconds then suddenly the wheel goes back to straight. Not sure what kind of stuff is going on but it feels uneasy so I have parked the car until it is repaired
My latest ball joint seemed to be really stubborn and refused to move, was at it for a while all on one side (Rear). Then I thought I might as well try hitting from the other side and pop, one hit and it came right out lol
As above, right on the heavy part where the ball joint goes through, turn the steering full lock either way depending on which side you're trying to hit to get better access.
Where exactly am I hitting this? Do you notice what's wrong with this ball joint, btw?
I changed out that ball joint and all my wandering and floating issues went away.
The previous owner installed new ball joints but apparently the locking plate and a bolt broke off causing the ball joint to move around a little and wear out I suppose? Mechanic who did the alignment failed to notice this worn part. New joint went in without any issues. Super easy job. I don't understand why I would need an alignment now, but he's going to do another one for free if I want.
