NYTDIBoy
So my passat is just under 3 years old, with just shy of 70k on the odo. A couple weeks ago I got a CEL, since I always have my tablet running torque to monitor regens, a few minutes after the light came on I see I have 2 codes, one for the NOx sensor, and the other for the heater circuit. The exact codes are:
One of my motorcycle riding buddies is the salesman who sold me the car, he runs into me as I am picking up the car and we go to his office to B.S. I ask him if there is anyway I can get a cost for the parts, he goes in to the parts department and they get me a listing of the part number. The description of the bad part number is "Control Unit with nox-sensor for emissions control". My buddy tells from chatting with guys behind the counter that the fact I have 2 codes showing bad indicates it's more than likely a controller issue rather than the actual sensor being the bad part. I was thinking perhaps when my turbo failed and dumped a ton of oil down the exhaust it had drastically shortened the life of the sensor. But as I said, the part is $518 before tax and the sensor is manufactured to be a part of the control unit. My buddy says to call VWoA, which I do the next day. The woman on the end of the line has no clue, and says the part is not covered because it's not a catalytic converter or the engine ECU. I tell her I need a written denial, which I get the next day. After reading it, she has denied my claim for "Knock sensor" as being it is not covered under the federal emissions warranty!
So after doing some research in my warranty manual and on the EPA's website, I find a discrepancy.I find this document on the EPA's website http://www3.epa.gov/otaq/regs/im/obd/pubs/420f15035.pdf that explains what is and isn't covered under the warranty. On page 4 we see this statement about what is covered.
In the warranty Manual on page 11 they say the following:
So what is consensus, do I take it up the you know what and pay $650 (plus the $129 already for the diagnostic) or do I have a case to take to the EPA and/or the New York State Attorney General? The problem is I have to get the car inspected in January and can't with those codes. I have read on here where some people have had it covered at the dealer no question asked and then other people were denied, but I don't know if it was covered under the bumper to bumper or the powertrain warranty.
Sorry for the long post, but it helps to get my frustration out!
18627 - NOx Sensor 1 Bank 1
P2200 00 [237] - Electrical Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 110208 km
Date: 2034.14.03
Time: 15:00:28
18640 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
P2209 00 [237] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 109745 km
Date: 2034.14.00
Time: 07:21:49
When I got to work that day I called the dealer I bought it from, they said they would not comment on weather or not it would be covered under the emissions warranty until they had diagnosed it, which would cost me $120 (+tax). So I make the appt, a week or so later. They call me and say it's not covered since there are only 3 parts that are covered under the warranty, The catalytic convertor, the ECU, and the OBD system. When I get back to the dealer to pick up the car, I explain to them I need a written estimate of what is wrong and what is needed. He says fine, he comes back 5 minutes later and I look at the estimate, all he has written down is a part number and a dollar amount ($650 / 8k0-907-807-e). P2200 00 [237] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 110208 km
Date: 2034.14.03
Time: 15:00:28
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 109745 km
Date: 2034.14.00
Time: 07:21:49
Notice it specifically calls the unit a "emissions control unit" much like the name of the part I need.There are three specified major emission control components, covered for the first 8 years or
80,000 miles of vehicle use (whichever first occurs) on 1995 and newer vehicles:
• Catalytic converters
• The electronic emissions control unit or computer (ECU)
• The onboard emissions diagnostic device or computer (OBD)
Armed with this knowledge I called VWoA back, they still stuck to their guns saying my faulty part is not covered because its not an ECM, OBD, or the cat. When I point out to them that their very own parts system refers to it as a Control unit for emissions, they still reply that it's not covered.....from a malfunction of a catalytic converter, particulate filter, engine electronic control module or on board diagnostic device (OBD)....
