Was a fordie
Eligible Seller Restitution
ESTIMATED TOTAL
2,955.87
seem right?
ESTIMATED TOTAL
2,955.87
seem right?
3. NOx catalyst/trap bank 1, efficiency below thresholdRecently I've started getting intermittent CEL's for 2 issues related to emissions.
1. Particulate trap bank 1, efficiency below threshold, sporadic
2. EGR system, insufficient flow, value of resistance too small
There isn't one exactly. There's a table of mileage adjustments (here's one; there are two others for different models) that goes in 5000-mile increments. For the Golf, which is what that table is for, the adjustment for a buyback ranges from $90/5k miles (for a very high-mileage 2010 car) to $500/5k miles (for a low-mileage 2015 car).Does anyone know what the per-mile rate is if you go over the mileage limit allowed between now and buyback date?
If you look at the mileage table, the buy back rate changes $360 or $390 (I can't remember which) per 5,000 mile interval.Does anyone know what the per-mile rate is if you go over the mileage limit allowed between now and buyback date? If may have been posted but can't find it.
Trying to decide to pull the trigger on something now and letting my TDI sit until buyback, or wait and drive it until buyback. I drive way more than the 12,500 annual/1,042 monthly mile limit. I would be about 625 - 700 miles over each month, assuming buyback occurs in 3 months, I would potentially have over 2,000 miles more than allowed. If it's 15 cents per mile - that's ok, but if it's 50 cent per mile, then it makes sense to do something now. Also, my A/C is starting to act up. I think it's the auto temp sensor not working properly because if I turn the "auto" switch on and off a couple times, the A/C finally kicks on. I have a service appointment next week, but other than fuel and regular maintenance, I'm not sinking another nickel into this car.
That is it. The rest goes to your lender to payoff the loan
Let's explain this better -
When you put in your information in , you should have noticed that it also asked for your lienholder, as well as an estimated balance on a certain date. After you clicked on submit, it went through and calculated the "raw" offer (this is the offer you would get if you did not have a loan ) and estimated your balance. It then subtracted the estimated balance due on the loan from your "raw" offer. This is the amount you saw presented to you.
The raw offer also included whatever owner's restitution you are due as well (your Minimum $5100).
You should have also have seen a value if you accept the fix. Yes - it will probably be less, but you still have a car.....
Wow, you drove it 180,000 miles, things are failing left and right, and you are getting $13,325 ?? I would be ecstatic.Well....
I was excited with the amount shown in the book for my 2011 jetta sw, $18,227-20,357.. Not so much now.. The website is showing a total of $13,325.. I just called and they said there was a $4,500 milage adjustment calculated on the website.. it has around a 180,000 miles now.. I would think the range shown in the book would have come a little closer than 5k bucks..
And of course, the AC just went out again today.. I'm sure that POS breakaway clutch has failed again.. What a crap design. ..... Rant over.
Sorry it is on the vw court settlement website not the claim website.
https://www.vwcourtsettlement.com/en/
Understood.No, the online portal has yet to ask for them or provide a way to upload them. I'm interpreting it as saying it will ask for that information prior to the 18 Oct hearing, but it isn't clear about that. It's entirely possible that they won't ask for anything else, or do anything to process any claims, until the settlement has been finalized.
The site is working fine. Hit the forgot username or forgot password block to get back in.Understood.
I asked because after registering and receiving email with case #, I have not been able to sign on again to the on-line portal - got an "Invalid credentials" message with a "9002" error.
Castle88
I have done the psswd changes with the "forgot psswd" option, but even though site accepts the change, it sends me back to log in and still keep getting rejected. I have also confirmed that site recognized my email address.The site is working fine. Hit the forgot username or forgot password block to get back in.
Aha! Just realized that I have been using Google Chrome browser. Switched to IE and connected successfully.Are you using something other than Internet explorer for a browser? If so, try using it to do the registration.
