gmcjetpilot
I have engine stripped. Injectors & cam cover tray off and
saw head bolts (triple square which I have). The cams are
in the way of head bolts. Is that correct you have to
remove the cam galley girdle and cams?
EDIT: You do NOT have to remove cams. The Cam shaft
has divots in the shaft to access the bolt heads.
My shop Manual.... Bentley Publishers is not detailed...
Eyeballing it, it looks like removal of camshafts are required
to remove head from bottom end...
ANY TIPS AND TRICKS?
Anyone? Buller? Buller? Buller? Ferris Buller?
