VW Still Believes In Diesels; Unveils New 2.0 TDI Mild Hybrid
Status
Not open for further replies.
kjclow
Charlotte, NC
I came to that same conclusion. I wonder if it helps on the V6?
tikal
Southeast Texas
2004 Passat Wagon (chainless + 5 MT + GDE tune)
If you want to see the most advanced automotive electronics in the world you can find them in the Tesla Model 3. Head and shoulders above anything else on the market. You can literally see how much more densely populated the PCB's are just by looking at them. Next level stuff.
https://insideevs.com/evannex-detailed-analysis-tesla-model-3-teardown/
Tesla Model 3 is definitively a very advanced luxury performance sedan that is going to continue to sell well for people who like performance luxury sedans. So if you like, for example, a smaller Audi sedan TDI or gasoline for performance, looks, luxury, etc. then the Model 3 Tesla will be pretty attractive to you. No doubt.
The folks in America that do not want/need a sedan will not be buying a Tesla Model 3, a Bolt, a Nissan Leaf, a Chevy Volt, etc. They will be looking at the latest shiny non-electrical SUVs and trucks with 0% financing and as many years to pay as possible, forecasting that the cost of fossil fuels at the pump will stay comparable to 1980's level, more or less, in the next few/many years (depending who you ask).
atc98002
Auburn WA
2014 Passat TDI SEL Premium (sold back), 2009 Jetta (sold back), 80 Rabbit diesel (long gone)
When I replace my Outback, it will be for something with a plug, and a sedan just isn't comfortable for this old body getting in and out. The Kona EV is attractive, but I'm waiting to see what VW is going to be bring out in the next year or two. They are showing off several cars with the ID tag that look interesting. Wonder if my VCDS cable is going to work on one? :D
flee
Chatsworth, CA
2002 Jetta GLS wagon
looking at the fuel MPG numbers, it does not look like the Hybrid system saves any MPG's-
RAM 1500 5.7 hemi
http://www.fuelly.com/car/ram/1500?e...=&submodel_id=
The new 5.7 hybrids
The fuel savings with a hybrid over a conventional vehicle will vary from 0 to as much
as 20% or more based on driving conditions and so will not always be observed by
the published mpg figure.
A hybrid driven at a constant speed on the highway will net 0 improvement in mpg.
A hybrid driven in stop and go traffic (difficult to standardize) will significantly add to
the mpg.
I can see this in my own hybrid, a 2008 Ford Escape.
tikal
Southeast Texas
To gauge meaningful differences in efficiencies of a passenger vehicle with a certain power train vs other kind of power train we need averages with at least tens of thousands of miles/Kms/etc. of MPG (or liters per 100 Kms etc.).
flee
Chatsworth, CA
True, but in regard to standardization: isn't that exactly what the EPA city driving cycle is meant to do?
Cheers,PH
Hopefully yes. It probably is mainly about trip length and time in heavy traffic.
For the non plug-in versions the city mpg can exceed the highway mpg.
casioqv
California
2009 Touareg TDI
This is true, but in practice the acceleration boost of the electric motor means you can get away with a smaller engine that runs more efficiently on the highway because it's at closer to full load. I guess this doesn't apply to to the car this thread is about, because it still has a 'full sized' 2.0 TDI.
JimInPB
Florida
1999.5 ALH Jetta
Aircraft starter motors are also alternators generating power. Ram is using a similar system for their new 2019 1500 Hybrids. The technology is coming.
I think that this technology has been around for quite a while. My 1960's vintage lawn tractor works this way. To add a modern twist with better efficiency, I know that regenerative variable frequency drives have been an off-the-shelf item in the industrial market since at least the 1990's.
The tough part with recapturing power in a car is having a place to put it that has enough capacity & a fast enough charge rate. Capacitors have the fastest acceptance rate, but only store a very limited amount of energy, even if they are the size of a trash can. Lead Acid batteries have a very slow acceptance rate, typically around 20% of their amp-hour rating when in bulk charging phase & much less when they are more than 80% full. The modern lithium based batteries have a fairly high acceptance rate & good power density, but they have other problems that are not well reported. First of all, the materials used in manufacturing them are very toxic. Second, the risk of fire is significant & putting out the fire can be a problem.
A few recent examples -
https://www.sun-sentinel.com/local/broward/davie/fl-ne-davie-tesla-crash-fole-20190225-story.html
https://fox6now.com/2019/03/02/tesla-burns-up-when-driver-goes-ice-fishing/
https://www.youtube.com/watch?v=CdaFk3w6rUY
[486]
MN
02 golf ALH
heh
go check out 'subcooledheatpump' on youtube, he had a chevy express van with a 30hp six pole induction motor hooked to a cobbled together VFD, 600V of car batteries on the DC bus of the inverter
turbobrick240
maine
The risk of fire is significant with internal combustion too. They catch on fire about every three minutes in the US. It's just that every EV fire makes headlines. So it's more an issue of public perception.
turbocharged798
Ellenville, NY
An EV fire is infinitely harder to put out. There is plenty of evidence to support that. Once that lithium starts burning, there's no stopping it.
turbobrick240
maine
Yes, they require a lot of water to extinguish. The good part is the fire generally developes more slowly than a petroleum fire, giving more time to escape.
kjclow
Charlotte, NC
Actually heated liquid lithium will react with water, thus adding another complication in fighting an ev fire.
turbobrick240
maine
It's not elemental Li in the batteries. Sort of like how elemental Sodium reacts violently/explosively when exposed to water but NaCl(salt) does not.
BeetleGo
Cambridge, MA
5-door, 5-speed Golf GLS replaced BeetleGo.
All I know is that my 2005 TDI with a psaltry 142k miles on it will last until my Tesla Model Y is made with induction charging gets off someone else’s lease (5-10 years). I can wait, but will!
I thought Volkswagen had the answer with diesels on biodiesel (which I use to this day @ 5-20 percent). But Volkswagen spoiled the diesel waters right about the time that an AMERICAN car company showed me that they were serious about changing the automotive word. Look around. They did! Tesla is the one to beat! :D
nwdiver
Texas
2003 Jetta TDI (sold); 2012 Tesla Model S
BeetleGo
Cambridge, MA
For charging while driving on a the road or charging at home? Home inductive charging is actually available now but there's a ~10% efficiency hit. IMO saving a few seconds plugging in isn't worth the additional energy... but it would be nice to not worry about forgetting. Though after awhile plugging in when you get home becomes a reflex.
Clearly you don’t park in the street in the city! They’ll have it figured out by the time I sign the papers! ;) Again, I’m willing and ABLE to wait. 10% NOW. Things will improve.
nwdiver
Texas
Hmmm... that's true. I don't expect the inductive efficiency to improve a whole lot. Steam plants were ~30% efficient 50 years ago... today they're ~33threeee % efficient? So a ~10% improvement? Only so much you can do with the laws of physics. ~90% efficient is probably pretty close to what's physically possibly unless we discover a room temperature super conductor.
I agree that for public and street side charging the 10% hit is probably worth it. Embed the inductive plate in the street and it's safe from vandals and you don't have to worry about the connector being sideswiped.
BeetleGo
Cambridge, MA
BeetleGo
Cambridge, MA
And aren’t we excited to have all of those early adopters? I see myself going electric in 5-7 years.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
HTML:
I am probably with you there. There is nothing to get excited about yet. The cars are hugely expensive for what they are and current battery technology just isn't there yet, by a long shot. Infrastructure still needs to be built out as well. I am glad for the early adopters as they are willing to throw large amounts of money at the issue with little regard to anything other than bragging rights really. My current 2015 Beetle tdi stop sale car should last me until the warranty runs out in another 10 years or so. Then I will check on what is available at that time.
turbobrick240
maine
HTML:
I'm glad for their contribution too. There's no doubt that bragging rights and the cool factor play a role in many EV purchase decisions, but I think the overwhelming majority of early adopters are motivated primarily by a concern for the environment.
Tin Man
Coastal Empire
Daughter's: 2004 NB TDI PD GLS DSG (gone to pasture)
While much electricity is produced by burning fossil fuel, I'm not impressed.
My 535d is rated among the best conveyances for CO2 emission environmental impact, and the X5 diesel "passed" the WVa NOx study.
We will see how the premium brands respond with decent driver-centered interior designs and better EV dynamics. It will happen as long as battery tech, IT, and charging infrastructure can keep their promises.
TM
turbobrick240
maine
I can think of many dozens of vehicles that get better fuel mileage than your 535d. A gasser that gets the same mileage per gallon is emitting less CO2 per mile. I'm sure it's a great car, but it's far from the most efficient.
flee
Chatsworth, CA
(snip)
TM
Maybe you'll be impressed knowing that your area's electricity is produced
mainly by burning natural gas - vastly cleaner than diesel internal combustion.
Though not my favorite, nuclear reactors rank second producing 26% in your area.
[486]
MN
02 golf ALH
cleaner, yes
more efficient? no
fuel to wheels is still more efficient than fuel to electric to battery to wheels
Status
