TDIMeister
Diesels are dying? Not so fast, says Volkswagen.
https://www.motor1.com/news/240543/vw-new-diesel-engine-revealed/
Then it won't start or charge because it replaces the function of the starter and alternator. You could put in an older bellhousing and conventional starter and maybe fit an accessory bracket from an older car with a conventional alternator, but who knows if the ring gear teeth on the flywheel will still exist...Now if someone will come up with an 'electric delete' for it . . .![]()
For 2019, the hybrid option won't be available on the ecodiesel. At least that's what the current press is saying.Aircraft starter motors are also alternators generating power. Ram is using a similar system for their new 2019 1500 Hybrids. The technology is coming.
I've thought on it too, with some big fat supercapacitors in the mix to suck up the fast spikes of power needed and produced. Some companies make wheel motors that bolt on, could be tossed onto the rear axle real easy.I'm all for a BAS system, although I question the utility of so much work being expended just to turn a non-firing engine in the 48V systems that have an e-drive mode (this TDI mild hybrid will not so I digress, but the 48V one used in the V6 TDI apparently will). More elegant would be to have the e-motor/generator in the bellhousing replacing/augmenting the clutch or torque converter.
I thought of doing a poor-man's regenerative retarder using a high-amp 12V alternator that is common in competition sound system circles. I'd add a bank of 18-20V li-ion batteries but nominally maintaining a ~60% SoC and standard 14.4V voltage. When I'm coasting or press a steering wheel button, the alternator would kick into full 18V and full amperage (300A is not uncommon), giving me 5.4 kW of retarding power that charges up the batteries. I can then descend down pretty decent grades without touching the brakes and recuperating the electrical energy as a bonus.
sort of like the old GT3 Hybbrid, you could use a flywheel. i'd swear it looks like one aboard the VW Pikes Peak entry, in pssgr seat.I've thought on it too, with some big fat supercapacitors in the mix to suck up the fast spikes of power needed and produced. Some companies make wheel motors that bolt on, could be tossed onto the rear axle real easy..
then you gotta do some oddball stuff with CVTs or maybe an electric motor driving the flywheel and acting as a generator the other way round. Eh, seems easier to just dump the electric into caps and then do whatever with it from there.sort of like the old GT3 Hybbrid, you could use a flywheel.
honda did a manual hybrid civic and insightHybrid...doesn't that dictate automatic transmission?
You joking? They'd be used lead acid off the scrap pile. I'm cheap.I hope those five batteries wouldn't be lead acid. Even cave men have moved well beyond that battery tech. for EV usage.
Your experience with the civic hybrid manula sounds better than mine. I looked at them about 13 years ago and thought the manual did more to keep the stop start technology from working correctly. Unless I was absolutely still, any time I released the clutch the engine would start. Even with the car in neutral and the brake fully applied. Reminded me of the hill hold feature we had in our 82 subie. The only time it worked was when you came to an absolute complete stop and pushed the brake pedal through the firewall before taking the car out of gear.honda did a manual hybrid civic and insight
the civic is the only one I've driven so far, was really neat, it'd shut off the engine sitting at a stop light in neutral, select a gear and it starts. If you stall it taking off, pull it into neutral and put it back in gear and it restarts. Such a freakin' cool feature, IMO.
Get a nice welder/generator on a trailer.I drove a used E-Golf last weekend, and that was a hoot to drive. However, the range is still a little too low for me to switch to full electric yet. Since VW still doesn't sell the new E-Golf in my state, used is all that's available, and those only have about an 80 mile range. The current model still only lists a range of 125 miles, and that is still a touch too little for me. Give me 150 true miles of range with the HVAC working and less than ideal conditions, then I'll consider it.
hm, that's strange, I'd have noticed that for sure as the only way I sit at stop lights is in neutral with my leg not getting all cramped up.Your experience with the civic hybrid manula sounds better than mine. I looked at them about 13 years ago and thought the manual did more to keep the stop start technology from working correctly. Unless I was absolutely still, any time I released the clutch the engine would start. Even with the car in neutral and the brake fully applied.
Well, be sure to suit up next time you're on one because the nominal voltage of aOne thing to point out with the voltage systems is OSHA regulates certain safety gear above I think 50 volts. That is why most forklifts stop at 48 volts and commonly are 36 or 48 volt systems. (edit)
Right now, there's a bunch of manual transmission mild diesel hybrids on the market, with more coming out soon (Hyundai/Kia are entering the market with diesel hybrid version of their compact CUVs).Hybrid...doesn't that dictate automatic transmission?
Thanks for sharing. The Kia Sportage is fairly small car or in American terms 'very small car'. A mild hybrid diesel would be ideal in my view in a larger vehicle such as a midsize wagon or a medium size SUV like the Honda CRV, Toyota RAV4, etc.Right now, there's a bunch of manual transmission mild diesel hybrids on the market, with more coming out soon (Hyundai/Kia are entering the market with diesel hybrid version of their compact CUVs).
https://www.motor1.com/news/242182/kia-sportage-diesel-mild-hybrid/
I think they are all using the Continental system. Not sure about the Suzuki mild hybrid (gas turbo) cars.
Here's a test drive of a Renault Scenic (Which has been in production with the system with a diesel/manual for some time) and a Golf (Continental tech demonstrator).
https://www.youtube.com/watch?v=yC76hK3MrOs
New Audis (A6/A8/A7) come with a Continental 48-V mild hybrid system as standard, however not with a manual.
A Sportage is not a very small car, it's a compact CUV, just like a CR-V or RAV4.Thanks for sharing. The Kia Sportage is fairly small car or in American terms 'very small car'. A mild hybrid diesel would be ideal in my view in a larger vehicle such as a midsize wagon or a medium size SUV like the Honda CRV, Toyota RAV4, etc.
