TDI_Coast2Coast
Received my recall letter yesterday....For the totaled car
Hopefully no recalls on the 6 speed manual
Have your fluids checkedDoubleLifeOfVeronique said:Does it stop the other noises when it's down shifting, like the spring recoiling sound when you come to a full stop, or the other clunking sounds?
I have no problems when I'm accelerating and it's switching gears, the only time mine sounds odd is when it's down shifting. Is this normal, or will the temp sensor fix it all?
I go in on Wed of this week for the recall work.
This pudding is child approved!securityguy said:Let them tell us what ever they want but the proof is in the pudding![]()
Drive it around town in 'Tip'. You'll see.rkskeet said:.. As far as the downshift slight bang you mentioned, I never noticed that with my vehicle..
And in the case of mine, tip and sport.Elfnmagik said:Drive it around town in 'Tip'. You'll see.
No, I mean when the trans is in 5th doing 30mph at 1000rpm.securityguy said:El, when you say "lug the engine in D"...what do you mean? If you mean that when you take your foot off of the accellerator, does it pull on the engine? Then YES...that is inherent in the DSG and not something that will ever go away. Remember, the DSG is really a manual tranny, not an AUTO tranny as we used to think of automatics.
Shift points are one thing I have no complaints about with the DSG. I'm sure VW intentionally kept shift points on the low side for mpg's. Mine makes every effort to keep RPM's to at least 1200. Yes, under unusual circumstances I may see 1100 or even 1050 once in a while, but a push on the pedal makes it downshift immediately.El Dobro said:No, I mean when the trans is in 5th doing 30mph at 1000rpm.
Mine doesn't downshift when you push on the pedal, you have to stomp on it and then it downshifts and takes off into the car in front of you. In the meantime, my engine doesn't like RPMs below 1700. That's when it lugs and the lower the RPMs, the more it lugs. Use S and Tip and you get the violent shifts. I have to use all three modes to get the car around.barshnik said:Shift points are one thing I have no complaints about with the DSG. I'm sure VW intentionally kept shift points on the low side for mpg's. Mine makes every effort to keep RPM's to at least 1200. Yes, under unusual circumstances I may see 1100 or even 1050 once in a while, but a push on the pedal makes it downshift immediately.
I never feel like the engine is in any danger from running UNDER LOAD at too low RPM.
Drive in 'S' if you want more aggressive shift points, but I sure don't want my 'D' reprogrammed - I like it just the way it is.
'09 JSW TDi, DSG
