[ QUOTE ]
Davin said:
[ QUOTE ]
nh mike said:
Yes, TDIs use less fuel, but for the same trip they put out more smog-forming NOx than a Hummer. Even more if you eliminate/adapt the EGR.
[/ QUOTE ]
Yup, but then look at the HC's. Almost all gassers emit considerably more HCs than an equivalent diesel vehicle - especially one running on biodiesel.
[/ QUOTE ]
OK.
These are values for the "HCHO" field, which I assume is hydrocarbon output.
2003 Volkswagen Jetta Wagon TDI 5-speed:
0.06 g/mi (this is "HC-TOTAL", there is no "HCHO" field
2003 Honda Accord 5-speed:
0 g/mi (meaning <0.001 probably given the sig digs of values for other cars)
2003 Hummer H2 Land Barge:
0.002 g/mi
[/ QUOTE ]
Where are you getting those figures from? That's completely different from all the figures I've seen. The data given by VW for the TDI (and the test data I've seen is BELOW this figure) is 0.0267 g/mile of total hydrocarbons. By comparison, a Honda Insight puts out around 0.04-0.05 g/mile in the tests I've seen.
I can't see any way that a Honda Accord puts out less than 0.001 g/mile of HCs - unless they're doing the test without the engine running, coasting downhill in neutral.
Of course, biodiesel then reduces the HC emissions compared to regular high sulfur diesel by a further 67%.
In general, diesels are cleaner on HC, CO2, and CO, while gassers are cleaner on NOx (due to lower temps) and particulate matter. Exhaust aftertreatment can clean up all of them - the main issue is that the level of sulfur in the fuel prevents some types of emissions equipment from being used - right now mostly on diesels.
[ QUOTE ]
I don't know if the above numbers can be compared, since the labels don't match (HCHO vs HC-TOTAL). Maybe someone else can look at the data (
http://www.epa.gov/otaq/crttst.htm) and figure it out.
EDIT: OK, well those numbers definitely can't be compared. HC-TOTAL is total hydrocarbon and HCHO is just formaldehyde.
[/ QUOTE ]
Ah, that makes more sense. Should read your entire post before I respond. /images/graemlins/smile.gif I'm too lazy to go back up and change mine though.
[ QUOTE ]
Here's numbers for NMOG (non-methane organic gas):
Hummer: 0.114 g/mi
Accord: 0.014 g/mi
Jetta TDI: 0.02 g/mi (this is HC-NM... hydrocarbon- non-methane)
[/ QUOTE ]
It would still be very surprising that an Accord is lower. Most likely it's due to the fact that right now, better emissions equipment can be used on gassers than on diesels. Without emissions equipment, diesels are lower on HC and CO, but higher on NOx and PM. Aftertreatment can do wonderful things though.
